Designing a Hydro Generator for my Farm
The discussion revolves around the design and feasibility of a hydro generator for a farm, utilizing a small creek and existing field tiles. Participants explore engineering considerations, potential energy calculations, and design options for harnessing renewable energy through hydroelectric power. The conversation includes technical details, assumptions about water flow, and the practicality of various turbine designs.
  • Experimental/applied
  • One participant estimates the flow rate of water through the field tiles and calculates potential energy based on weight and height, suggesting a possible output of around 3 horsepower.
  • Another participant challenges the initial assumptions about the height of the water drop, suggesting that the actual drop may be less than initially thought, which would affect power calculations.
  • A later reply proposes digging the receiving basin deeper to increase the gravitational potential energy available for the hydro generator.
  • One participant mentions using a micro hydro calculator, estimating that 100 kWh per month could be generated during wetter months, which aligns with the farm's monthly energy needs.
  • Another participant shares a link to a tutorial on water turbines and notes the existence of designs suitable for low flow, low head situations.
  • One participant expresses uncertainty about the adaptability of water wheels for electric generation and considers a Kaplan turbine as a more suitable option.
  • There is a discussion about the potential to lower water levels by removing a small dam downstream, which could increase the head available for the generator.
Participants express varying levels of confidence in their calculations and assumptions, with some agreeing on the potential for generating energy while others question specific details. Multiple competing views on design approaches and calculations remain, and the discussion has not reached a consensus.
Participants acknowledge uncertainties in their measurements and assumptions, particularly regarding the height of the water drop and flow rates. The discussion includes references to external resources for further exploration of turbine designs and calculations.
This discussion may be useful for individuals interested in renewable energy solutions, particularly those exploring hydroelectric power generation in small-scale or rural settings.
drewk79
Over the past few years I have like many of you become interested in renewable energy.
Over the past few months we have gotten a lot of rain.
We also have a small creek in our pasture and it begins with 2-12 inch field tiles. The end (beginning i guess) has been filling with silt over the past 20 years and has now reached the top of the retaining wall so we need to build a new one a few feet taller.
I am thinking why we are down there working it may be a perfect opportunity to set up a small hydro generator.
I can weld and build basically anything ( I am a home builder) and my brother is a commercial electrician so I think we have the know how. I am just looking for some engineering and design help/suggestions.
OK so while I was down there the other day the 2-12 inch tile were running at what seemed to be full capacity. Maybe 60% full I would think that would be about 1 gal per sec per tile. If anyone has any opinions on that I am guestimating.
It is probably running 20%-30% higher than avg right now. Water weighs about 8 lbs per gallon. So ... I think i can reasonably get to 10 lbs a second avg. And it falls about 1 ft initially out of the tile. We have nice concrete walls on 3 sides and a concrete floor for about 10 ft. I will be adding a illustration soon.
OK I have done some more research and found I have 2-12 inch tile and they can flow 2 cubic ft per sec each. I think avg is probably 1/4 of that. appx 60 lbs per cubic ft. So avg work done is 30lbs drops 1 ft per sec on avg.
30 x 60sec = 1800 lbs 1 ft per minute
550 ft lbs a min = 1 hp
So i have a little over 3 hp
750 watts per hp x 3 = 2250 watts
2250 x 24 hrs a day= 54kWh
Any comments on these assumptions would be great.
Thanks
You're so close to having figured it out yourself (maybe you have, but you put ? in there...). Power is in foot-lb/min and you have information in units of feet, lb, and min. Put them together!
If I'm understanding you correctly, you only have a 1 foot drop to work with? anyway, potential energy is simply weight times height and power is flow rate times height. So if you have 60 lb/min dropping 1 foot, you have 60 ft-lb/min of energy at your disposal. That is about 1/10th hp, or 70 watts.
1 ft of drop seems awfully small, but if that's what it is, ok. Flow rate is pretty easy to find, though, if your water source is coherent: find yourself a 5 gal bucket, direct the water flow into it and measure how long it takes to fill it.
So 2 minutes of research made me redo my assumptions.
As far as the 1 ft of work that is about how far the tile are from the concrete floor. maybe 18 inches but its under water so its hard to see and remember from yesterday.
I did edit my first post so if you could reread it with the new assumptions and let me know what you think so far
Amateur hour again... I don't really know anything about the subject. I am wondering, however, if you could dig the receiving basin a couple of feet deeper to gain more gravitational assistance from the falling water.
Are you calling me an amateur? I know I am. But I am trying to learn and I find this site very helpful. Should I just keep my comments to myself or...
If you were talking about yourself being an amateur I enjoy all points of view.
I have found a micro hydro calculator and I according to it 100 kWh a month are possible in the wetter months. Also since I am at the beginning of the creek I have a perfect opportunity to harness this energy for a very low initial cost.
So far I am imagining a 6 ft radius water wheel a pulley and shaft up to dry land. At that point I could have a mounting plate for 3 generators (or one big one) They could be connected and disconnected very easily.
100 kWh is about the entire farm monthly use. So maybe just a 2-3 year return on investment.
Thank you I had not thought about wiki
I went to the creek again this morning. I was expecting some rain according to the radar but nothing and I am trying to decide how tall to make the new dam for overflow water.
The tiles though where in fact still flowing I would say 80% max. So I think it will be easy to take another piece of 12 in tile and build a small model in the garage and then simply side it into place once completed.
I will keep you updated.
That is indeed the case; I hoped that you would understand that. :smile:
I feel pretty intelligent when I talk to friends and peers but I get a bit intimidated on when I put some ideas out there for others to see.
In reference to the generator I have found there is a small dam about 100 yards doinw the creek. I can lower the water by removing it. This will get me to about 3 ft of head.
Also I have found water wheels are not easily adapted to electric generation so I am looking at a kaplan style turbine.
  • · Replies 18 ·
