Designing Torque Wrench: Seeking Help on Calculations
The discussion focuses on designing a torque wrench that can accurately measure torque exerted on a nut using a sensor. The user seeks assistance in calculating the necessary spring tension to ensure the gear locker maintains connection with the handle at specified torque levels. They describe two designs: one using a direct gear connection and another utilizing a spring mechanism to manage torque settings. There is also a request for resources or links to help with the calculations involved in the design. The thread highlights a shared interest in torque measurement solutions among participants.
flashlaser
Hi I'm designing a torque wrench. But i need some help.
the gear connects to the socket. If I'm putting 300ft/lb torque on a nut using the socket connected to the gear. and the gear connection to the handl thru the gear locker, and the gear locker can push against the weight. Will the gear locker push against the weight with 300ft/lb? the weight is actually a sensor. I want the sensor to be able to sense that there is 300ft/lb of torque being exerted on the nut
Now my second drawing torque2.jpg uses a spring like a normal torque wrench.
at the end of the handle there will be a dial that will tighten and losen the spring which pushes against the gear locker, which in turn keeps the gear connected to the handle. say i put the wrench of 150lb/ft torque using the dial, then the spring pushes the gear locker with enough force to keep it connected up to 150lb/ft torque, if it goes over, the gear's teeth push the locker and spring back and it disconnects form the handle.
how would i calculate the spiring tension, etc to get this working. Can someone give me links, leading me to the right direction.
Thanks for any answers.
bumping up
Hi Flashdancer,
Did you ever get a reply to your question concerning this matter?
I am also loking for help on a similar topic (actually it's almost identical!)
Regards
Steve.
I need some assistance with calculating hp requirements for moving a load. - The 4000lb load is resting on ball bearing rails so friction is effectively zero and will be covered by my added power contingencies. Load: 4000lbs Distance to travel: 10 meters. Time to Travel: 7.5 seconds Need to accelerate the load from a stop to a nominal speed then decelerate coming to a stop. My power delivery method will be a gearmotor driving a gear rack. - I suspect the pinion gear to be about 3-4in in...
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Turbocharging carbureted petrol 2 stroke engines'
Hi everyone, online I ve seen some images about 2 stroke carbureted turbo (motorcycle derivation engine). Now.. In the past in this forum some members spoke about turbocharging 2 stroke but not in sufficient detail. The intake and the exhaust are open at the same time and there are no valves like a 4 stroke. But if you search online you can find carbureted 2stroke turbo sled or the Am6 turbo. The question is: Is really possible turbocharge a 2 stroke carburated(NOT EFI)petrol engine and...
