Are all 2x2 Matrices with det(A) = 0 a Subspace of M2x2?
  • Thread starter Thread starter OFFLINEX
    Subspace
OFFLINEX
Determine whether all 2x2 matrices with det(A) = 0 are a subspace of M2x2, the set of all 2x2 matrices with the standard operations of addition and scalar multiplication.
Must pass in order to be a subspace
Closure property of addition - If w and v are objects in A, then w+v are contained within A
Closure property of scalar multiplication - If K is any real number scalar and v is any object in A, then kv is also in A
I wasn't sure where to really start with this one so I picked a matrix with a determinant of 0
B2x2 = [[w1,w2][w1,w2] and added it to another det=0 matrix C2x2 = [[v1,v1][v2,v2]]
Added together they make D2x2 = [[w1+v1,w2+v1][w1+v2,w2+v2]] which wouldn't have a det of 0 so this wouldn't be a subspace right?
You have the right idea, but to make this a proof you need to either (1) give specific values for v_1, v_2, w_1, w_2 which show that the result matrix is invertible, or (2) compute the determinant of your result matrix in terms of v_1, v_2, w_1, w_2 and prove that this expression takes nonzero values.
Ok then an example that would disprove this as a subspace would be
[[3,13][3,13]]+[[5,5][7,7]] = [[8,18][10,20]]
det of [[8,18][10,20]] = -20 so it fails
Yes, this is correct.
There is also a simpler example (which doesn't match the pattern you gave): \left( \begin{array}{cc} 1 & 0 \\ 0 & 0 \end{array} \right) + \left( \begin{array}{cc} 0 & 0 \\ 0 & 1 \end{array} \right) = \left( \begin{array}{cc} 1 & 0 \\ 0 & 1 \end{array} \right).
