Details of total internal reflection
3 replies · 2K views
Consider snell's law [itex]n_1 \sin{\theta_1}=n_2 \sin{\theta_2}[/itex]([itex]n_1[/itex] and [itex]n_2[/itex] are real).
We know that if [itex]n_2<n_1[/itex], there exists an incident angle called critical angle that gives a refraction angle of ninety degrees i.e. [itex]\sin{\theta_c}=\frac{n_2}{n_1}[/itex].
But if the incident angle is greater than the critical angle(i.e. [itex]\sin{\theta_1}>\frac{n_2}{n_1}[/itex]),Then:[itex]\sin{\theta_2}=\frac{n_1}{n_2}\sin{\theta_1}>1[/itex]
But we know that [itex]\sin{\theta}>1[/itex] can happen for no real [itex]\theta[/itex],so we say that [itex]\theta_2[/itex] should be complex:
[itex]\theta_2=\alpha+i \beta[/itex] and [itex]\sin{\theta_2}=\sin{(\alpha+i \beta)}=\sin{(\alpha)}\cos{(i \beta)}+\sin{(i \beta)}\cos{(\alpha)}=\sin{(\alpha)}\cosh{(\beta)}+i\cos{(\alpha)}\sinh{(\beta)}[/itex]
But from snell'w law,we know that [itex]\sin{\theta_2}[/itex] should be real and so we should always have [itex]cos{\alpha}=0 \Rightarrow \alpha=\frac{\pi}{2}[/itex] and so [itex]\sin{\theta_2}=\cosh{\beta}[/itex].
This means that the only variable which is capable of giving information about the Total reflected ray,is [itex]\beta[/itex]. But how?
Thanks
You cannot use a law in a parameter range where it does not apply.
What else do you need? The angle is just the same as the incident angle.
No reason to use complex angles here. You simply defined [itex]\beta[/itex] such that [tex]\cosh \beta = \frac{n_1}{n_2}\sin \theta_1[/tex]
Now, what you do get from the treatment of this problem with complex angles is an expression for the evanescent waves [itex]F = A e^{i\vec k_2\cdot \vec x},[/itex] where [itex]\vec k_2 = cos\theta_2\hat i + sin\theta_2\hat j[/itex], and [itex]\vec x = x\hat i + y\hat j[/itex]. Now if you plug in your complex parametrization [itex]\theta_2 = \frac{\pi}{2} + \beta[/itex], than you get [tex]F = A exp [iy\,cosh\beta - x sinh\beta][/tex]
