Determine an expression for distance traveled and the time elapsed
The discussion focuses on deriving expressions for the distance traveled and time elapsed by a self-propelled vehicle with constant power and mass. The acceleration is defined as a = P/mv, leading to the relationship between acceleration, velocity, and distance. The user attempts to integrate to find distance and time, resulting in expressions involving initial and final velocities. Feedback is provided on the need for clarity regarding constants in the equations. The final expressions for distance and time are confirmed as reasonable with minor adjustments suggested.
thestiggg
A self propelled vehicle of mass m travels in a straight line. The vehicle has an engine which provides constant power P so that the acceleration 'a' at an instant is given by a=P/mv where v is the speed of the vehicle and all frictional resistance is neglected. Determine expressions for:
a) the distance traveled,
b) the time elapsed
a=P/mv
I took the derivative of a so,
a=dv/dt then tried to get to v=ds/dt
I ended up with this
ds/dt=sqrt(2p/m + Vo^2)
welcome to pf!
hi thestiggg! welcome to pf! :smile:
b) the time elapsed
you mean ds/dt=√(2pt/m + vo2) ? :wink:
but i suspect the question wants answers to a) and b) as functions of v …
try the standard chain rule trick a = dv/dt = dv/ds ds/dt = v dv/ds :smile:
Yes sorry I missed the t but that's what I meant. I'll give it a try and get back to you
EDIT: and should I integrate and evaluate to v, vo, s and so?
yup! :smile:
Is it safe to assume that vo, so is = 0 according to the question?
Okay so for a) I used "v dv = a ds " and I got " (m/p)*((v2^3-v1^3)/3) + so = s "
For b) I used a=dv/dt and I got " t= (m/p)*((v2^2-v1^2)/2) "
Does that look reasonable?
i don't think so
oops!
oh I'm sorry! :redface:
i was replying to your post #5, i didn't notice your post #6 at all (it came in a few seconds before mine) …
yes, that's fine! :smile:
(except for the constants in the first one: you need either a constant s0 or a constant v0, not both!
also, you should use v and v0, not v1 and v2 :wink:)
