Determine if function forms a vector space
The problem involves determining whether the set of all functions \( y(t) \) that have a period of \( 2\pi \) forms a vector space under the operations of function addition and scalar multiplication. The discussion references trigonometric functions and the properties required for a set to qualify as a vector space.
  • Participants explore the closure properties of the set under addition and scalar multiplication, questioning how to demonstrate these properties for general periodic functions.
Some participants have suggested a structured approach to proving the closure under addition and scalar multiplication, while others emphasize the need to consider a broader class of periodic functions beyond the commonly known ones. There is an ongoing exploration of definitions and properties relevant to the problem.
Participants note the importance of defining the set of functions clearly and the implications of periodicity on the operations being considered. There is an acknowledgment of the need to organize the proof more effectively.
Carson
Problem- Determine if the set of all function y(t) which have period 2pi forms a vector space under operations of function addition and multiplication of a function by a constant.
What I know- So I know this involves sin, cos, sec, and csc. Also I know that a vector space must be closed under addition and multiplication by a scalar. I'm aware of how to prove polynomials are vector spaces, but not any other function.
u+v ∈ V
c*u ∈ V
[/B]
u=a1*sin(t)+a2*cos(t)+a3*sec(t)+a4*csc(t)
v=b1*sin(t)+b2*cos(t)+a3*sec(t)+a4*csc(t)
u+v ∈ V
c*u ∈ V
[/B]
You should forget the periodic functions you know for the moment. All you have here is a general periodic function. That is a function ##y(t)## for which ##y(t+2\pi)=y(t)## for all ##t\in \mathbb{R}##. Now you have to show that the two properties mentioned under 2. hold.
So does it make sense to say the following in order to prove this set is a vector space:
f(t+2π) + g(t+2π)= (f+g)(t+2π) = f(t) + g(t) = (f+g)(t)
(cf)(t+2π) = c [ f(t+2π) ] = c [f(t)] = (cf) (t)
This is close, but should be better organized in the first part of your proof.
Let's define U as ##U = \{f | f(t + 2\pi) = f(t)\}##, and assume that ##f, g \in U##.
Start with ##(f + g)(t + 2\pi)## and show that this equals ##(f + g)(t)##. This shows that when f and g are in U, then f + g is also in U; IOW, it shows that set U is closed under vector addition.
The other part looks fine, and shows that for a function f in U, then cf is also in U; i.e, that U is closed under scalar multiplication.
I agree with what @fresh_42 said about forgetting about the periodic functions that you already know. There are lots more periodic functions than the ones you listed. For example, there are sawtooth functions that are periodic with period ##2\pi## and lots more.
  • · Replies 23 ·
  • · Replies 18 ·
