Determine its maximum angular displacement?
The discussion revolves around calculating the maximum angular displacement of a simple pendulum with a length of 1.53 m and a mass of 6.74 kg, given an initial speed of 1.36 m/s. The period of the pendulum is determined to be 2.48 seconds. To find the maximum angular displacement, the conservation of energy principle is suggested as the method of calculation. The initial kinetic energy at the equilibrium position is converted into potential energy at the maximum displacement. The final goal is to express the maximum angular displacement in degrees.
andric_mcneil
Really Stuck here I've got the period but after that like i said I'm stuck
A simple pendulum having a length of 1.53 m and a mass of 6.74 kg is given an initial speed of 1.36 m/s at its equilibrium position. Assume it undergoes simple harmonic motion.
(a) Determine its period.
2.48 s
(b) Determine its maximum angular displacement.
Use conservation of energy.
