zeralda21
- 119
- 1
Three ropes, numbered 1-3, are joined at one point. Three persons pull in each separate rope, so that the rope is at rest. The angles between the ropes are shown in the figure (note that it is the lengths as illustrated, and not the size of the forces). Arrange the drag forces in the ropes, called F1, F2 and F3 respectively, according to their size (eg, "F1 <F2 <F3" or "F1 = F3 <F2").
http://bayimg.com/EaoNIaaDh
No equations needed. Maybe some basic trigonometry.
My thoughts:
First I conclude that the force depends on the length of the rope. If one rope is much shorter than the two other, then the force needed for the system to be at rest will be much larger for that rope. The same works in the opposite direction(large rope-->small force).
Since F_3 is significantly longer than F_1 and F_2, I conclude that both F_1 and F_2 are larger than F_3. Notice now that the length of rope 1 and 2 are equal. If forces F_1 and F_2 were equal, then the angle of F_3 with the horizontal axis would be 45 degrees which is not the case. The angle is actually less than 45 degrees and therefore is F_2 larger than F_1.
Hence: F_2>F_1>F_3. Correct answer: F_3>F_1>F_2
