Determine the medicine's flow speed through the needle
  • Thread starter Thread starter LesVampires
    Flow Needle Speed
The discussion focuses on calculating the flow speed of medicine through a hypodermic syringe when a force is applied to the plunger. Participants emphasize using Bernoulli's equation and the continuity equation, noting that the pressure in the needle remains constant at 1.00 atm. There is confusion regarding the application of these equations, particularly in determining the correct flow speed and the relationship between pressure and area. The conversation also touches on the need to account for the pressure exerted by the plunger and how to integrate this into the calculations. Overall, the thread seeks to clarify the mathematical approach to solving the problem.
LesVampires
A hypodermic syringe contains a medicine with the density of water (see figure below). The barrel of the syringe has a cross-sectional area of 2.20 10-5 m2. In the absence of a force on the plunger, the pressure everywhere is 1.00 atm. A force of magnitude 1.80 N is exerted on the plunger, making medicine squirt from the needle. Determine the medicine's flow speed through the needle. Assume the pressure in the needle remains equal to 1.00 atm and that the syringe is horizontal.
second question
An 11.3 kg block of metal is suspended from a scale and immersed in water, as in the figure below. The dimensions of the block are 12.0 cm 8.7 cm 8.7 cm. The 12.0 cm dimension is vertical, and the top of the block is 5.00 cm below the surface of the wateri know that P=Po + pgh p=m/v and g i can't figure h out
can u direct me a bit with this ty verymuch
http://www.princeton.edu/~asmits/Bicycle_web/Bernoulli.html
height stays same so it cancels
solve for v
hmm i know that Av= Av and the equations but i keep gettin a wrong answer... A= 2.2x10^-5 m^2
P_1 + 1/2 \rho v^2 + \rho gy_1 = P_2 + 1/2\rho v^2 + \rho g y_2
don't forget atmospheric pressure is at the end of the needle solve for v2
P=F/A to find the pressure exerted over the area of the plunger (force exerted on plunger )
After finding the equivalent pressure that is due to the plunger, add that to atm pressure.
show me what you did and I'll tell you what your doing incorrect.
well the pgys are 0 u have v= 2change in P/pv pv is A right? P=1.01 x10^5 and
yes pgy is 0 so what is the equation then?
not sure what your saying when you say
v=2change in P/pv pv is A
:confused:
and the area is small on the end of the syringe but did they give it to you?
Look at the post above (last post by me) I added stuff.
I have to go but I'll see what you did tommorow (post your work)
A2/A1<<1 -> note
isnt that what's left of the equation?
what are you talking about.
No the A1V1=A2V2 is the continuity equation and that is substituted into the bernoulli equation. And then you can solve for v2 which you want.
