Determine the times at which the velocity=0
  • Thread starter Thread starter teng125
The acceleration of a particle is given by a = A - 6t^2, with initial conditions of x(0) = 8m and v(0) = 0. The velocity can be derived from acceleration, leading to the equation v = At - 2t^3 + C, where constants A and C can be determined using known velocity values at specific times. The particle's velocity is zero at t = 0s and t = 4s, indicating maximum displacement from the origin. The total distance traveled by the particle by t = 5s is calculated by considering both the outward and return journey, resulting in a total distance of 144.5m. Understanding the difference between displacement and total distance is crucial for accurate calculations.
teng125
the acce of a particle is a=A - 6t^2 where A is a constant. At t=0,the particle starts at x=8m with v=0. Knowing that at t=1s, v=30m/s.
pls help...
the answer is 0 and 4s
Now that you are given the acceleration of the particle, do you know how to find the velocity from the initial condition? (Remember: acceleration is the time derivative of the velocity).
ya,i tried to get dv/dt=A-6t^2 to v-v(initial)=(At-2t^3) - (At[initial] - 2t^3[initial]).but i think it is wrong...
what eqn do u get to form??
v = At - 2t^{3} + C
You know v(0)=0 and v(1) = 30, so you can work out A and C. Once you have that, solve v = 0.
for part b) what is the total distance traveled by the particle when t=5s??
i try to integrate and get x=16t^2 - 1/2t^4 + 8 but when i try to do,the answer is wrong.
the answer is 168.5...pls help
The particle first moves away from the origin until v = 0.
How far has it traveled ? How long did it take ?
How much further does it travel, on the way back, until t = 5 sec ?
firstly is my eqn correct above??
i try to find all the way from t=1 to 5 and found it goes back...what should i do
Yes, your eqn is correct.
You just have two distances, the distance out and then a bit more, coming back, to find.
Think of it like a particle in shm. It starts at the origin. Moves out a distance and then moves back towards the origin again.
That is what this particle is doing, although the movement is certainly not shm.
Find out when the velocity = 0. That is when the particle is at its max. distance from the origin. What is the value of t ?
Use your eqn to find out the distance, x, from the origin. That is how far it has traveled so far.
Now find its distance from the origin at t = 5. What distance has the particle moved back by ?
Now what is the total distance moved ?
i thought the problem stated that at t=0,x=8 and v=0 also.so it started at 8 for t=0.
then at t=5s, i got 95.5
is it correct??
x in the equation is displacement, not the distance travelled. If you move 100 m and come back adistance 20 m, the total distance traveled is 120 m but the displacement is only 80 m. In the same way the particle is moving forward till v=0 and then comes back, you have to find distance travelled
Everything in your last post is correct, but ...
The particle starts from the origin, moves out by about 130 odd metres, stops momentarily (v=0, t < 5) then moves back again towards the origin such that at t = 5, its distance from the origin is then 95.5 m
You have to (first of all) find out its distance from the origin, when v=0.
What's the eqn for velocity ?
now when v=0,t=- or + 4s.so i substituted into the eqn x=16t^2 - 1/2t^4 + 8 , i got 120.
then i try to take 120-95.5=24.5 and then plus 120 =144.5.However,the answer is incorrect.Where did i go wrong??
You got 120 by subtracting 8 instead of adding it!
