Determining intial rates of reaction
  • Thread starter Thread starter dnt
    Reaction
To determine the initial rate of the reaction between C2H5Br and OH-, the concentrations of both reactants are crucial, as they influence the rate according to the rate equation. The initial rate can be calculated using the formula rate = k[C2H5Br][OH], where k is the rate constant that varies with temperature. The provided concentrations of 0.16 M for C2H5Br and 0.26 M for OH- indicate that the reaction is not at equilibrium, as equilibrium would require equal concentrations. The activation energy and frequency factor may be relevant for calculating k at the specified temperature of 85 degrees. Understanding how to apply these concentrations in the rate equation is essential for accurately determining the initial reaction rate.
dnt
problem states:
C2H5Br + OH- --> C2H5OH + Br-
if the reaction mixture is .16 M C2H5Br and .26 M OH-, then what is the intial rate of reaction at 85 degrees.
they also give a table of different temperatures and the associated k values at each. i also determined the activation energy and frequency factor for the reaction (if it matters at all for this question).
my main question is, is the fact that there are two different concentrations given make a difference in the answer? how do i use those numbers? shouldn't they be the same if the reaction is at equilibrium?
thanks
What is rate equation?
i think i solved it:
rate = k[C2H5Br ][OH]
correct?
I don't get how to argue it. i can prove: evolution is the ability to adapt, whether it's progression or regression from some point of view, so if evolution is not constant then animal generations couldn`t stay alive for a big amount of time because when climate is changing this generations die. but they dont. so evolution is constant. but its not an argument, right? how to fing arguments when i only prove it.. analytically, i guess it called that (this is indirectly related to biology, im...
