Determining Steady State Current in an Inductor Transient
The discussion revolves around determining the steady state current in an inductor after a switch operation in a circuit. Participants explore various approaches to model the inductor's behavior during the transient phase and the conditions for steady state, including the application of relevant equations and circuit analysis techniques.
  • Homework-related
  • One participant presents an initial current of 6A for the inductor, which is later corrected to 4.8A due to a calculation error.
  • Some participants suggest modeling the inductor as an inductor at rest with a parallel current source, while others propose using an exponential response based on initial and final conditions.
  • There is discussion about the voltage across the inductor and its implications for finding the steady current, with references to the relationship V=L di/dt.
  • Participants explore the concept that inductors do not allow instantaneous changes in current, similar to capacitors with voltage.
  • One participant mentions the steady-state resistance of an ideal inductor being zero, leading to treating the inductor as a short circuit in steady-state analysis.
  • There are multiple calculations and transformations discussed, including source transformations and equivalent resistances in the circuit.
  • Confusion arises regarding the correct application of circuit analysis techniques, leading to backtracking on initial assumptions and calculations.
Participants express differing views on the initial current and the correct approach to modeling the inductor's behavior. There is no consensus on the final steady state current, as various calculations and interpretations are presented throughout the discussion.
Participants highlight limitations in their understanding of how to incorporate the inductor into circuit analysis, particularly regarding initial conditions and the behavior of inductors versus capacitors. There are unresolved mathematical steps and dependencies on definitions that affect the conclusions drawn.
This discussion may be useful for students and practitioners interested in circuit analysis, particularly those studying transient responses in RL circuits and the behavior of inductors in various configurations.
R0CC0
1. The problem statement
See attached question -
So I have this inductor transient question and can't seem to get the right answer. Basically I don't know how to determine the current in steady state after switch operation.
tau = L/C
iL = a+be-t/tau
V=IR
tau = 4/8 = 0.5sec
iL(0-) = 6A
6A = a + b
then I'm not sure what happens after switch operation.
Any help appreciated thanks!
How did you arrive at 6A for the initial inductor current? Show your work.
Your initial current is not right.
One way to solve after the switch is opened is to model the inductor as an inductor at rest with a parallel current source carrying the inductor's initial current.
Another way seems to be what you are doing. You know the response will be first order and follow an exponential. The trick is to get the exponential equation right and to do that you have to look at your initial and final conditions. At time 0, iL = iL(0-). At time infinity, iL = ?. I know you know this one :)
Then see if you can fit an exponential response to those two conditions.
Does io(0-) = 4.8 Amps sound better?
6 was a typo. I went 12x(4/10). Total current x resistance of interest/total resistance
Yeah definitely forgot to put that one in iL(∞) = 0
So that would give me an answer of io(t) = 4.8e-2t ??
Is that right?
I'm not sure how the inductor would act at io(0+)
I only learned that for capacitors. Would this effect it?
And is my new initial current now correct, or did I not take the inductor into account?
No, that's not right. The total resistance as seen by the voltage source (before the switch opens) is not 10Ω. Also, when determining the current through a particular resistor that is in parallel with another, the ratio you want is to place the resistance that's NOT of interest over the total resistance. If you think about it, you expect the lower resistance of a pair to carry more of the current, so it should have the higher ratio value...
Inductors will not let their current change instantaneously, much like capacitors won't let their voltage change instantaneously. So the current through the inductor at t = 0+ must be the same as it was at t = 0-.
You've got the right form of the equation but still the wrong initial current.
We're assuming the circuit is at steady state just before the switch is thrown. This means all the currents and voltages in the circuit are constant.
Take a look at the equation governing the V/I relationship of an inductor: V=L di/dt. If all currents are constant, what does that say about the voltage across the inductor? Does that make it easier to find the steady current flowing through the inductor?===== a little extra
I just want to add (and then correct a mistake I made above!), when you know the response is first order, you always know the voltage or current will follow either Ae-t/τ or A(1-e-t/τ). You just need to know what the voltage/current is at t=0 and what it is at t->∞ to know which of these the result is. That, added to knowledge of what τ is -- L/R in RL circuits and RC in RC circuits, is a very useful shorthand to get circuit behaviour for first order circuits. (The R in the time constant equations is the R seen by the inductor or capacitor).
If you don't have a trick at hand for higher order circuits, you have to solve the usual way. Incorporating initial conditions for inductors and capacitors comes directly from the Laplace transform. Inductors: v=L di/dt -> V(s) = sL I(s) - Li(0), Capacitors: i = C dv/dt -> I(s) = sC V(s) - Cv(0). Notice how in the laplace domain, an inductor looks like a resistor of value sL in series with a battery of value -Li(0) (The voltage V(s) appears across the two in series). Also a capacitor looks like an admittance of sC-- equivalently an impedance of 1/sC -- with a current source of -Cv(0) in parallel.
I don't know if you've studied that yet, but above I said you could replace the inductor with an inductor in parallel with a current source to model its initial condition. Actually
I should have said the inductor could be modeled as an unenergized inductor in series with a battery of -Li(0) volts
(the sign acts to generate the initial current direction). If you put that into the circuit, you could solve the usual way for circuit behaviour including initial conditions.
I didn't think it was. I just don't know how to sub the inductor into it.
Ahh so the initial voltage through the resistor is zero!
Do I then treat that branch as if it is no longer connected?
Sorry you are probably putting the answer pretty much in front of me and I'm not seeing it.
So obviously we are going to end up with a negative due to the size of the inductor.
Ok so we then have 24V = sL x 12A - 4i(o)
Now sL = 1??
therefore i(o) = -3
therefore -3e-2t?
Im not sure how i got sL = 1 though?
By the way thanks both of you for the help so far.
The DC steady-state resistance of an ideal inductor is zero. That means that "after a long time", when all transients have died away, an inductor looks like a short circuit: zero ohms.
To find the steady-state conditions of a given circuit, replace inductors with wires (shorts) and remove all capacitors (opens). Then calculate the currents and potentials as required.
Thanks that makes sense. I remembered that for capacitors, just forgot for inductors.
So that would then give me 4Ω||4Ω (parallel) then in series with the 2Ω, which would then give me a total 4Ω resistor. And since current runs through each resistor in series equally that gives me 24/4 = 6A. Wait now we are back to the start.
I'm sorry I'm really not seeing the answer!
One of those 2 ohm resistors is 4Ω||4Ω. So that 6A passing through the 2 ohm equivalent resistor is splitting between those two branches.
Ahh of course, I then thought that went in series with the 2 ohm, but if I use source transformation I get two parallel 2ohm resistance, thus giving me two separate branches.
Thanks that gets me the right answer I think.
i(0) = 3A (initially)
Thanks heaps for your help. :)
V= IR, the voltage is across the resistor, the current is through the resistor
V = L di/dt, the voltage is across the inductor, the current is through the inductor
If di/dt = 0, then V = voltage across the inductor is zero which means it looks like a wire.
No, it has nothing to do with the size of the inductor. The sign is just falling out of the math. The important thing is the initial voltage has to drive the initial current in the right direction and that is how you determine what the sign is.
V = L di/dt
The voltage is across the inductor and that looks like a resistance of sL in series with a voltage of Li(0). So it is valid to replace an inductor with non-zero initial current with an unenergized inductor in series with a voltage source.
This is what would be done if the circuit was too complicated to know that form the answer is. You would replace your state elements (inductors and capacitors) with equivalent circuits that contain initial conditions and then solve with the usual KCL, KVL.
But the path you've chosen is the easier one with first order circuits. You already know the answer so you are fitting initial and final conditions to it to nail down the constants.
yes that's it, 3A :)
Ok awesome, I think I understand now. Thanks heaps :) I'll go try another transient with an inductor and see how i go.
12K
