Determining the Force acting on a Particle
  • Thread starter Thread starter kacete
    Force Particle
To determine the force acting on a particle moving in the XOY plane, the derivative of the movement equation must be calculated to find velocity, followed by another derivative for acceleration, which is then applied to Newton's Second Law. The individual is struggling with the problem and has attempted to evaluate it at t=0 and t=1 to derive vectors for velocity. There is a clear need for assistance in understanding the correct approach to solving the problem. The discussion highlights the challenge of reversing the process from force to position. Overall, the focus is on applying calculus and Newton's laws to solve for the force on the particle.
kacete
A particle of mass
moves across the XOY plane following the equation:
I'm totally clueless about this one.
I know I have to find the derivative of the movement equation to find the velocity and then again to find the acceleration and use it on Newton's Second Law of motion.
(The previous exercise was the reverse problem, given the F(t) eq, find the x(t) eq.)
I tried t=0 and t=1, and given the resulting vectors the velocity could be found? :frown:
Anyone?
