Solving Detonator Paradox in Edwin F. Taylor's Spacetime Physics
  • Thread starter duordi
  • Tags
    Paradox
In summary: Once the cap hits the U, the T is no longer a rigid object since different parts are moving at different speeds, I'm not sure it even makes sense to talk about "Lorenz contraction" for a non-rigid object. Yes, that's correct. But can we prove the two frames agree quantitatively? One simple proof is just to note that if you treat the bottom of the arm of the T and the cap of the T as separate objects and calculate when each one hits the U, there is a spacelike separation between the two hit-events (remember that the spacetime interval between events is the same in every frame, so if it's spacelike in one frame it's spacelike in every frame
duordi
78
I broke down and bought Edwin F. Taylor’s Space time Physics
I am having trouble understanding the detonator paradox.
The book states that there will be an explosion but it doesn’t explain why.
Am I suppose to say the story violates one of these principles.
Special relativity problems intended to be paradoxes usually involve some careful thinking. First of all, for special relativity to apply, the two postulates proposed by Einstein have to be true:
1) The bodies involved must have uniform velocity. No acceleration is permitted.
2) The speed of light is the same for all observers in all frames.
Or is this explanation correct I found it on the web.
Fom Edwin F. Taylor's Spacetime Physics, P.185, problem 6-5. A U-shaped structure contains a detonator switch connected by wire to one ton of the TNT. A T-shaped structure fits inside the U, with the arm of the T not quite long enough to reach the detonator switch when both structures are at rest. Now the T is removed to the left and accelerated to high speed. It is Lorentz- contracted along its direction of motion. As a result, its long arm is not long enough to reach the detonator switch when the two collide. However, look at the same situation in the rest frame of the T structure. In this frame the arm of T has its rest length, while the two arms of the U structure are Lorentz-contracted. Therefore the arm of the T will certainly strike the detonator switch. The question is whether there will be an explosion. Figure: | =======+ |====== S|~~~~TNT (S denotes the switch) | =======+ <--x-> <--y--> The answer is there will be an explosion. Someone said that due to there is no absolutely rigid body so the arm of T will continue its motion for some time even the cap of T strike the arms of U. But can we prove the two frames agree quantitatively? In the rest frame of T, the sufficient condition for the explosion is x>=y*Sqrt [1-v^2], but in the rest frame of U, the condition depends on when the arm stop and I can't make it agree with the condition in the rest frame of T exactly. How do you resolve it?. How do you resolve it?
One simple proof is just to note that if you treat the bottom of the arm of the T and the cap of the T as separate objects and calculate when each one hits the U, there is a spacelike separation between the two hit-events (remember that the spacetime interval between events is the same in every frame, so if it's spacelike in one frame it's spacelike in every frame)--this should be sufficient to show that there's no possible way that the event of the cap hitting could have any causal influnce on the end of the arm of the T until after the arm hits the U.
As viewed by the observer on the U, does T getting longer undo the Lorenz contraction of T as the T slows to the speed of U?
Duane
Of course the answer is, it doesn't matter! If the U and T collide at relativistic speeds you get an explosion anyway.:biggrin: All that kinetic energy has to go somewhere!
Duane
Once the cap hits the U, the T is no longer a rigid object since different parts are moving at different speeds, I'm not sure it even makes sense to talk about "Lorenz contraction" for a non-rigid object. And in U's rest frame the T must actually end up stretched to longer than its rest length. Whether the different parts of the T oscillate a little and finally lose their relative velocity so the T looks rigid again, or whether the T breaks apart during the impact, or whether something else happens, all depends on the detailed physical properties of the T, but it's not important for solving the problem.
In the rest frame of U, x>=y*(1-v²). The bottom of the T can't stop before a light signal from the "earlier" collision reaches it. That means xmax>=(1-v²)/(1-v)>1.
1. What is the detonator paradox in Edwin F. Taylor's Spacetime Physics?
The detonator paradox is a thought experiment proposed by physicist Edwin F. Taylor to illustrate the concept of time dilation in special relativity. It involves two observers, one stationary and one moving at a high velocity, experiencing a different sequence of events when observing a detonator explosion.
2. How does this paradox challenge our understanding of time?
The detonator paradox challenges our understanding of time because it shows that time is not absolute and can be experienced differently by different observers depending on their relative velocities. This goes against our everyday intuition that time is the same for everyone.
3. What is the resolution to the detonator paradox?
The resolution to the detonator paradox lies in the principles of special relativity, specifically time dilation and the relativity of simultaneity. These principles explain that time is not absolute and can be experienced differently depending on the observer's perspective and relative velocity.
4. How does this paradox relate to other concepts in physics?
The detonator paradox is closely related to other concepts in physics such as the twin paradox, which also involves the effects of time dilation on two observers with different relative velocities. It also relates to the concept of spacetime, which combines space and time into a single entity.
5. What are the implications of the detonator paradox?
The implications of the detonator paradox are far-reaching, as it challenges our understanding of time and space and has led to the development of the theory of special relativity. It also has practical applications, such as in the design of GPS systems, which must take into account the effects of time dilation on satellite clocks moving at high velocities.
