Question-can a neutron star shed mass?
Neutron stars can shed mass through several mechanisms, primarily during their early stages when temperatures exceed approximately 10^9 K, leading to significant heat loss via neutrino emission. As the star cools, thermal photon cooling occurs, which is proportional to T^4 K. Additionally, interactions involving electrons can result in the emission of neutrino-antineutrino pairs, contributing to mass loss. The process of deleptonization, which occurs in protoneutron stars, is crucial for mass loss, as neutrinos are emitted for up to 1 million years depending on the state of the matter. Overall, any heat loss from a neutron star correlates directly with a reduction in mass.
Duane M
Question--can a neutron star shed mass?
Once the steller core of a massive star collapses into a neutron star, is there any known mechanism by which the neutron star can shed mass?
Astronomy news on Phys.org
Yes. When a neutron star is "new" with temperatures above ~ 109 K, there is strong heat-loss (therefore mass) by neutrino emission. At lower temperatures, there is "standard thermal photon cooling", which has a power proportional to T4 K. Another process is where an electron passes by a nucleus and, instead of emitting a single photon emits a neutrino-antineutrino pair. This has a power of about T6.
Either way, the heat loss translates to mass loss by emission of various particle types. There are more complicated processes which involve interaction of the (huge) magnetic field, but the bottom line is that any heat loss will also lead to a mass loss.
Yes. When a neutron star is "new"...
By "new" I think that you mean when is exactly what is called a protoneutron star. Then yes, it loses all its neutrinos by a process called deleptonization
Even after the protoneutron star (PNS) stage, neutrino emissions dominate for ~100 years in the "standard" model and as much as 1 million years in certain cases depending on the state of the "superfluidity" of the degenerate matter.
100 to 1 million years certainly extends well beyond the PNS stage. Deleptonization is a description of the change in properties of the matter in a neutron star, neutron loss is called neutron diffusion. See at least pages 1-4 (out of 61) at:
http://arxiv.org/PS_cache/astro-ph/pdf/0012/0012136.pdf
Is a homemade radio telescope realistic? There seems to be a confluence of multiple technologies that makes the situation better than when I was a wee lad: software-defined radio (SDR), the easy availability of satellite dishes, surveillance drives, and fast CPUs. Let's take a step back - it is trivial to see the sun in radio. An old analog TV, a set of "rabbit ears" antenna, and you're good to go. Point the antenna at the sun (i.e. the ears are perpendicular to it) and there is...
3I/ATLAS, also known as C/2025 N1 (ATLAS) and formerly designated as A11pl3Z, is an iinterstellar comet. It was discovered by the Asteroid Terrestrial-impact Last Alert System (ATLAS) station at Río Hurtado, Chile on 1 July 2025. Note: it was mentioned (as A11pl3Z) by DaveE in a new member's introductory thread. https://www.physicsforums.com/threads/brian-cox-lead-me-here.1081670/post-7274146 https://earthsky.org/space/new-interstellar-object-candidate-heading-toward-the-sun-a11pl3z/ One...
