Do Diagonals Always Confirm a Quadrilateral is Convex?
  • Thread starter Thread starter mathstudent88
mathstudent88
Here is the problem:
If the diagonals of a quadrilateral intersect each other, then the quadrilateral is convex.
Proof:
Let ABCD be a convex quadrilateral. Since quadrilateral ABCD is convex, A and D are on the same side of line BC, and D and C are on the same side of line AB. Thus D is a member of the int(angle ABC). With the Crossbad theorem, BD intersect AC = {P} where C-P-R. So AC intersect BC = {Q} where D-Q-R. Since A, B, C, D are noncollinear points P=Q. So AC intersect BD = {P} = {Q}. Which proves that AC intersects PR = the empty set. Since a convex quadrilateral has the property that its diagonals intersect then ABCD is conves.
How is this? I really didn't know what to do for it. Can someone please help me with it?
Thank you!
Proof:
No. You cannot start with "Let ABCD be a convex quadrilateral". That is what you are asked to prove. Start with the hypotheis that the diagonals intersect. Or you can use "indirect" proof: Suppose the quadrilateral is NOT convex. Then what can you say about the diagonals?
[/quote]How is this? I really didn't know what to do for it. Can someone please help me with it?
Thank you![/QUOTE]
Is this better?
Let ABCD be a quadrilateral.
If A and B are on the same side of the line CD and B and C are on the same side of the line DA then B is in the interior of angle ADC. The Crossbar theorem says that the ray DB intersects the segment AC at some point P.
Similarly A is in the interior of angle BCD which implies ray CA intersects segment BD at some point Q.
Thus P and Q lie both on the lines AC and BD.
Being diagonals, these lines are not the same and so P=Q is the common point of intersection.
Because of this, these four condition hold:
A and B are on the same side of line CD
B and C are on the same side of line DA
C and D are on the same side of line AB
D and A are on the same side of line BC
making the quadrilateral convex.
Thanks for the help!
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
