Diff Eq. - swapped coefficients help
Sparky_
In an L-R-C circuit, L = 1, R = 2, C = 0.25, E(t) = 50 cos(t)
Find the steady state solution
L \frac {di(t)}{dt} + R \frac {dq(t)}{dt} + \frac {q}{C} = 50cos(t)
\frac {di(t)}{dt} + 2 \frac {dq(t)}{dt} + 4q = 50cos(t)
q(t) = e^{-t}(c1cos(sqrt(12)t + c2sin(sqrt(12)t)
next annihilate 50*cos(t)
(D^2 +1) (D^2 + 2D + 4) = (D^2 +1)50cos(t)
roots = +/- i
qp(t) = Acos(t) + Bsin(t)
[-Acos(t) - Bsin(t)] - 2Asin(t) + 2Bcos(t) + 4Acos(t) + 4Bsin(t) = 50cos(t)
cos(t)[-A+2B+4A] + sin(t)[-B-2A+4B] = 50cos(t)
3A+2B = 50
3B-2A = 0
A = \frac {150}{13}
B = \frac {100}{13}
qp(t) = \frac {150}{13}cos(t) + \frac {100}{13}sin(t)
The book gets
qp(t) = \frac {100}{13}cos(t) - \frac {150}{13}sin(t)
I'm off with swapped coefficients and the sign.
Do I have something crossed?
Where is my error?
Thanks
-Sparky
Are we to assume that i= dq/dt?
How did you get that? If you took i= dq/dt so that di/dt= d2q/dt2, then characteristic equation is r2+ 2r+ 4= (r+2)2= 0 and the general solution (to the associated homogeneous equation) is
q(tt)= c1e^{-2t}+ c2 te^{-2t}
roots = +/- i
3A+2B = 50
3B-2A = 0
A = \frac {150}{13}
B = \frac {100}{13}
The book gets
Where is my error?
Thanks
-Sparky
You are correct on the first (homogeneous solution) - I had an obvious error in my work. I didn't recognize the obvious solution and made a mistake in factoring.
(However, I don't need that solution to get the steady state) I need the particular qp(t)
the (D^2 +1) (D^2 + 2D + 4) = (D^2 +1)50cos(t)
the second term is the solution to the homogeneous - as you pointed out q(tt)= c1e^{-2t}+ c2 te^{-2t}
The (D^2 +1)
roots = +/- i
with all the equating coefficients is where my error is.
Thoughts?
-Sparky
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
