Difference between Taylor Series and Taylor Polynomials?
The discussion clarifies the distinction between Taylor Series and Taylor Polynomials, specifically using the example of the function ex. The Taylor Series for ex is expressed as ex = ∑n=0(xn/n!), which contains an infinite number of terms. In contrast, a Taylor Polynomial, such as 1 + x + x2/2! + x3/3!, represents a finite approximation of the Taylor Series, where the degree of the polynomial determines the accuracy of the approximation. Higher degree polynomials yield better approximations of the function at a given point.
  • Understanding of calculus concepts, particularly series and polynomials.
  • Familiarity with the exponential function ex.
  • Knowledge of convergence in mathematical series.
  • Basic skills in manipulating mathematical notation and expressions.
  • Study the convergence criteria for Taylor Series.
  • Explore the concept of Maclaurin Series and its applications.
  • Learn about error estimation in Taylor Polynomials.
  • Investigate other functions' Taylor Series expansions, such as sin(x) and cos(x).
Students of calculus, mathematics educators, and anyone interested in understanding series approximations and polynomial functions.
NicolasPan
Hello,I've been reading my calculus book,and I can't tell the difference between a Taylor Series and a Taylor Polynomial.Is there really any difference?
Thanks in advance
(For simplicity I take an example with Taylor series at x=0, also know as a Maclaurin series.)
Taylor series and Taylor polynomials are related, but not the same.
##e^x = \sum_{n=0}^\infty\frac{x^n}{n!} ## is the Taylor series for the function ##e^x##.
The series has (for a function that is not a polynomial) an infinite number of terms.
##1+x+\frac{x^2}{2!}+\frac{x^3}{3!}## is a Taylor polynomial for the function ##e^x##.
For each k you can have a Taylor polynomial for the function ##e^x##: ## \sum_{n=0}^k\frac{x^n}{n!}##.
These polynomials consist of the terms of the Taylor series up to a certain power of ##x##. The basic idea is that a complicated function could be approximated by a polynomial, by dropping the higher order terms from the Taylor series, as these become smaller and smaller.
A polynomial has a finite number of terms, a series has infinitely many terms (except possibly if all but finitely many terms are 0). The Taylor polynomials are the partial sums of the Taylors series.
The Taylor series for ex about x=0 is 1 + x + x2/2! + x3/3! + x4/4! + ... that is, it has infinitely many terms.
The Taylor polynomial of degree 2 for ex about x=0 is 1 + x + x2/2!, so it is a polynomial of degree 2,
the Taylor polynomial of degree 3 for ex about x=0 is 1 + x + x2/2! + x3/3!, a polynomial of degree 3, etc.
The higher the degree of the Taylor polynomial, the better it approximates the function at x, if the Taylor series converges to the function at x.
Thank you! Simple and clear explanation
Thanks a lot!
  • · Replies 19 ·
  • · Replies 17 ·
16K
