Differential by another differential
  • Context: Undergrad
  • Thread starter Thread starter Nick R
    Differential
The discussion revolves around the derivation of the product rule in calculus, specifically addressing the treatment of the term dudv and the justification for considering it as negligible or equal to zero. Participants explore the implications of different mathematical frameworks, such as standard calculus and non-standard analysis, in understanding differentials and their properties.
  • Some participants question the validity of stating that dudv = 0, arguing that while it is a small number, it is not zero unless limits are taken.
  • One participant suggests that the proof of the product rule is only valid in non-standard calculus, where differentials have a rigorous definition that leads to the conclusion that the product of differentials is zero.
  • Another participant emphasizes that the differential of a function can be defined without the need for infinitesimals or limits, relying instead on the definition of the derivative.
  • There is a discussion about the interpretation of differentials in non-standard analysis versus differential forms, with some participants expressing confusion over terminology.
  • One participant introduces the concept of hyperreal numbers and discusses the properties of infinitesimals, suggesting that dudv is infinitesimal with respect to both du and dv.
  • Another participant elaborates on the definitions of halo and galaxy in relation to infinitesimals, proposing that these definitions may clarify why dudv is considered negligible in the derivation.
Participants do not reach a consensus on the treatment of dudv. There are multiple competing views regarding the validity of considering dudv as zero, with some advocating for non-standard analysis and others supporting traditional calculus approaches.
The discussion highlights the limitations and assumptions inherent in different mathematical frameworks, particularly regarding the treatment of infinitesimals and differentials. The varying interpretations of the product rule and the role of limits in calculus are also noted.
Nick R
In deriving the product rule,
d(uv) = (u + du)(v + dv) - uv
= udv + vdu + dudv
The next step in the derivation is to consider dudv = 0 because it is "negligible". I have seen this elsewhere too.
I can see that dudv would be a very small number, but why is it valid to say that dudv = 0?
See if this helps: http://web.mit.edu/wwmath/calculus/differentiation/products.html"
= udv + vdu + dudv
It is only zero when the limit is taken.
the differential is defined as
dy=lim Δy
it is know from finite calculus
Δ(uv)=(u+Δu)(v+Δv)-uv
=uΔv+vΔu+ΔuΔv
lim ΔuΔv=0
but ΔuΔv is not 0
clearly if Δu and Δv are each o(Δx)
ΔuΔv is o((Δx)^2)
= udv + vdu + dudv
That proof, while not a bad "rough" way of seeing what is happening, is only valid in "non-standard calculus" where you have first given a rigorous definition of "differentials" (which itself requires some pretty deep logic in order to extend the real number system). IF you had done that then you know that, from the definition of differentials, the product of any differentials is exactly 0.
Better to stay with the "more complicated on the surface but simpler in essence" proof using limits.
You're confusing nonstandard analysis with differential forms (and/or dual numbers).
The differential of a function f is a function of two variables defined by df(x,h)=f'(x)h. The product rule for differentials follows from that definition and from the product rule for derivatives. No need to let h be small, or to take any limits.
What (branch or topic in mathematics) defines the operator d() and the associated "differentials" such as dx?
Depends on exactly what you mean. I interpreted what you said a treating the differentials directly- i.e. in "non-standard analysis" and was taken to task for it. If you are referring to the differential defined as Fredrik says (I would write the notation a little differently) it should be covered in any Calculus text.
I was under the interpretation that if du and dx are infinitesimals (with respect to the real numbers), then the galaxy of dudx does not contain either du or dx (i.e., dudx is infinitesimal with respect to both du and dx), but because the Hyperreals are a field, if du and dx are both non-zero, then dudx is non-zero.
Sorry, I should define some of those terms:
A Hyperreal y is infinitesimal with respect to x if there for all real numbers r
|ry| < |x|
Similarly, x is said to be unlimited with respect to y if the above holds.
A number is said to be infinitesimal if it is infinitesimal with respect to the real numbers, and a number is said to be unlimited (or infinite) if it is unlimited with respect to the real numbers.
The halo of a number x is the set of all numbers y such that x - y is infinitesimal with respect to x (I might be wrong about this... it might be that they are infinitesimal with respect to the real numbers)
The galaxy of a number x is the set of all numbers y such that x - y is not unlimited with respect to x (again, I might be wrong about this, it might be that they are not unlimited with respect to the real numbers, but in my post I was using the definition that they are not unlimited with respect to x)
Since X=aR where a is some real number and R is any real number (x is some multiple of any real number), I'd think definitions for galaxy and halo must be with respect to any real number.
Looking at those definitions, maybe this is why dudv is considered 0 in the derivation...
say you are differentiating uv with respect to x
start with
= udv + vdu + dudv
but we want the ratio of this with respect to an infintesmial change in x so we divide by dx
dividing...
d(uv)/dx = u(dv/dx) + v(du/dx) + (dudv)/dx
and since dudv is infinitesimal with respect to dx, or, |r(dudv)| < |dx| ; r is a real number
(dudv)/dx = 0
similar to how
Lim(a -> 0) [ a / b ] = 0 ; b is some real number != 0
So for any limited hyperreal number (anything that is not infinite with respect to the real numbers), there is exactly 1 real number in its halo
(Also, now that I think about it, i do think that the definition of galaxy and halo are with respect to the real numbers because otherwise, the only number in the halo of 0 would be 0, but with the usual definition, the halo of 0 is every infinitesimal number. In that case, what I meant is that dudv is infinitesimal with respect to du and dv, so you can ignore the stuff about galaxy and halo there)
The only number real number in the halo of an infinitesimal number is 0, so if we take the real number closest to d(uv)/dx, you get uv' + vu'
where v' is the x derivative of v and u' is the x derivative of u
(since the real number closest to (dudv)/dx is 0, that part disappears)
  • · Replies 22 ·
12K
  • · Replies 21 ·
