Differential calculus question
noahsdev
The number of termites in a colony is increasing at a rate proportional to the number present on any day. If the number of termites increases by 25% in 100 days, how much longer (to the nearest day) will it be until the population is double the initial number?
2. The attempt at a solution
\frac{dT}{dt}=at
T=∫at
=\frac{at^{2}}{2} + c
T(x)=T
T(0)*\frac{5}{4} = T(100)
=> a=\frac{c}{20000}
I think I am approaching this wrong. Help is appreciated,
thanks.
**UPDATE: I overlooked a something, I think I figured it out now. I got t=200, does that seem right?
Your initial equation seems to be wrong. The rate of change of the population is proportional to the population (on the same day).
\frac{dT}{dt}=at
T=∫at
T(x)=T
thanks.
Your expression ##T(t) = a t^2/2 + c## is incorrect; it does NOT satisfy the condition that the derivative ##dT/dt## is proportional to ##T## itself.
\frac{dT}{dt}=at
ManiFresh and Ray Vickson's point is that this is not the correct equation. Saying that "the rate is proportional to the number present" is \frac{dT}{dt}= aT.
The "T" on the right is the number of termites, not the time in days.
T=∫at
T(x)=T
thanks.
So how do I solve it? I mean, are you saying the rate of change is dT/dt = aT?
I cannot see how to answer this question without doing your problem for you. I suggest you look through your textbook or course notes to find an answer. You could also do a Google search under "growth models", for example.
What is the derivative of ln(y) with respect to t, if y is a function of t?
Chet
You need to get both "dT" and "T" on the same side of the equation, "dt" on the other side.
