Differential Eq falling object + friction
iloveannaw
A point mass m falls from rest through a height h. The frictional force is given by -\gamma \dot{z} and gravity by -mg.
Give the 'equation of motion' (differential equation) for the height z(t).
\ddot{z} = -g - \frac{\gamma}{m} \dot{z}
I thought about integrating then rearranging:
\Rightarrow \dot{z} = -gt - \frac{\gamma}{m}z +c_{1}
\Rightarrow z(t) = - \frac{m}{\gamma} (\dot{z} + gt + c_{1})
The question the asks what kind of differentional eq. this is and asks the student to make the following substitution:
\dot{z}(t) = v(t)
and asks what kind of equation it is now! Well I haven't got a clue what its is on about. I assume something like s = ut +\frac{1}{2}at^{2} should come out. Have to hand this in tomorrow so please help!
hi iloveannaw! :smile:
iloveannaw said:
The question the asks what kind of differentional eq. this is and asks the student to make the following substitution …
it means substitute in the original equation (the one beginning z'') :wink:
thanks, so you think I should start by working from \frac{dv}{dt} = -g -\frac{\gamma}{m}v ?
I have already done that, but the question is quite clear it asks for the diff. eq. in terms of \dot{z}(t) and then asks the student to make substitution. And it also asks for type of differential equation before and after.
that is the differential equation in terms of z' (your other one was in terms of z' and z) …
and you should be able to solve it :smile:
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
