How do I find the constants A, B, and C for this differential equation?
In summary, after solving the differential equation and rearranging, it was found that the constants A = -1/2, B = -1/2 and C = -3/4 satisfy the given function y = Ax^2+Bx+C. This was determined by equating like terms and evaluating the expression at x=0.
loadsy
57
Find constants A, B, and C such that the function y = Ax^2+Bx+C satisfies the differential equation y''+y'-2y=x^2
2. The attempt at a solution
d/dx (y) = d/dx (Ax^2+Bx+C) = 2Ax+B
y' = 2Ax+B
d/dx (y') = d/dx (2Ax+B) = 2A
y'' = 2A
Now subbing back into the differential equation given:
(2A) + (2Ax+B) - 2y = x^2
2A + (2Ax+B) - 2(Ax^2+Bx+C) = x^2
2A + 2Ax + B - 2Ax^2 - 2Bx - 2C = x^2
Moving the left hand side around:
(2A-2C+B) + (2A-2B)x - 2Ax^2 = x^2
However, now I have to solve for the constants and I'm not exactly sure how to figure that out. Any help would be great! Thanks guys :D
Well, in the final equation, you have an x^2 term, an x term and a constant on the left, while you have only an x^2 term on the right. Now, based on this, what can you conclude about the coefficients on the left?
Well the coefficients on the left hand side if we were to rearrange it to
-2Ax^2 + (2A-2B)x + (2A-2C+B)
would be -2, 1, 1 which in a way is kind of similar to the equation:
-2x^2 + x+ 1 which is a polynomial. However, I'm not too sure if I should be moving the x^2 term from the right hand side over to the left hand side and solving for 0. Haha I'm sorry if I didn't really answer your question.
Okay, let me put in a different way...
Suppose ax^2+bx+1 = 3x^2+cx+d (a,b,c,d constants)
What can you say about a, b, c and d?
Hmmm I must not be seeing the logic behind this at all, and usually I would. Maybe I'm just having an off day or something. 12 years of schooling and 1 year of University is failing me today. The only thing I can think of would be that you are moving the right hand side over and subtracting it to be:
ax^2+bx+1 - 3x^2 - cx - d = 0
(a-3)x^2 + (b-c)x - d + 1 = 0
I feel really silly right now for not understanding because I know it is more likely really simple because the same principle for what you are asking will apply to my above question.
The way to solve a problem like
[tex]a_nx^n + \cdots + a_1x + a_0 = A_nx^n + \cdots + A_1x + A_0[/tex]
is to split this one equation into n equations by grouping like powers of x:
[tex]a_nx^n = A_nx^n[/tex]
[tex]a_1x = A_1x[/tex]
[tex]a_0 = a_0[/tex]
from which [itex]a_k = A_k[/itex].
How does this work? Evaluate the expression at x=0. The constant terms are all that are left; they must be equal. The higher-order powers must be equal as well (prove recursively). You don't need the proof to solve the problem. Simply equate like terms.
OHHH alright! Thank you so much both of you. That last explanation I think helped the most. I knew it could not be a hardship to figure it out but I made it seem harder than it should be. The keywords that helped me the most was "equate like terms" which I know is what neutrino was trying to state too.
Going back to my question, I'm finding that A = -1/2, B = -1/2 and C = -3/4 I believe. I'm hoping that is right anyway. :D
Thanks.
Bingo!
Excellent, yeah I just went back and subbed into my formula the answers I just got:
- 2Ax^2 + (2A-2B)x + (2A-2C+B) = x^2
Which ends up equaling x^2 on both sides, so the identity must be true.
Related to How do I find the constants A, B, and C for this differential equation?
What is a differential equation?
A differential equation is a mathematical equation that relates one or more functions and their derivatives. It is used to model relationships between quantities that change continuously over time or space.
What is the purpose of studying differential equations?
The study of differential equations allows us to understand and analyze complex systems and phenomena in various fields such as physics, engineering, economics, and biology. It also provides us with tools to predict and control the behavior of these systems.
What are the types of differential equations?
Differential equations can be classified into three main types: ordinary differential equations (ODEs), partial differential equations (PDEs), and stochastic differential equations (SDEs). ODEs involve only one independent variable, while PDEs involve multiple independent variables. SDEs involve random components in their equations.
What are the methods for solving differential equations?
The methods for solving differential equations depend on the type of equation. Some common methods include separation of variables, substitution, and variation of parameters for ODEs, and separation of variables, change of variables, and Fourier transforms for PDEs. Numerical methods, such as Euler's method and the Runge-Kutta method, are also used to approximate solutions to differential equations.
What are some real-life applications of differential equations?
Differential equations have various applications in different fields, such as modeling population growth, predicting weather patterns, designing electrical circuits, and analyzing chemical reactions. They are also used in engineering to design and control systems, in economics to study market trends, and in biology to understand biological processes.
