Differential equation/ spring application
Punchlinegirl
A mass weighing 8 lb stretches a spring 1.5 in. The mass is also attached to a damper with coefficient γ . Determine the value of γ for which the system is critically damped; be sure to give units for γ .
I have no idea where to start. Can someone help me out?
You have to review your text on the general solution to the differential equation for damped simple harmonic motion. There is a good explanation http://hyperphysics.phy-astr.gsu.edu/hbase/oscda.html#c1"
AM
The fact that "A mass weighing 8 lb stretches a spring 1.5 in." tells you the spring constant. What is the standard differential equation for a spring with damper?
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
