Differential Equations Assignment (small step needs clarification)
Mozart
When given
y'' + ay' + by + c = 0
The characteristic equation is:
λ^2 + aλ + b = 0
Now I'm making a substitution of e^(λx) to get
[(λ^2 + aλ + b)][e^(λx)] = 0
double root : [(λ - alpha)^2] [e^(λx)] = 0
My question now is that if I were to do the same thing with the following equation would it follow that
y''' + ay'' + by' + cy +d = 0
Characteristic equation λ^3 + aλ^2 + bλ + c
then making the same substitution ( λ^3 + aλ^2 + bλ + c ) e^(λx)
NOW HERE IS MY QUESTION: Can I write the above as
[(λ - alpha)^3][e^(λx)]
or do I have to write it a different way. Thank you very much.. I know this doesn't really have much to do with the solving of differential equations but it would be very helpful if I knew that that was correct for my assignment.
Thanks.
Thanks.
You can write it like that, if the roots are repeated.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
