How to Solve for an Object's KE and Heat in a Differential Equations Problem?
steven452
We're supposed to find the object's KE and heat. Given:
Forces on Object: Air Drag + Gravity
Air Drag = .5(coefficient of drag)(1.2 kg/m3)v2A
A = cross sectional area
R = Radius of object
Object is X Km above the ground
Initial velocity = V
We are told it should be an initial value problem.
Possibly y"+ (Force due to Drag)y' + (gravity)y = 0
I tried plugging in the initial conditions to the equation above, but I'm stuck at that point.
How did you get that equation?
Since kinetic energy has nothing to do (directly) with position, you shouldn't have to solve for y (which I'm assuming stands for the height of the object); instead, focus on v(t), and don't forget that a(t) = dv/dt
I just sort of assumed that's the equation we had to use, but I wasn't sure?
What initial value differential equation should I be using?
You should be able to derive an equation using Newton's second law and what you know about the forces acting on the object
I was originally going to do it entirely with Newton's laws, but I'm having a hard time seeing how Newton's equations can "convert" into DE?
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
