Differentiation and Lebesgue integration
AxiomOfChoice
Suppose g(x) = \int_0^x f(t) dt, where f is Lebesgue integrable on \mathbb R. Give an \epsilon - \delta proof that g'(y) = f(y) if y\in (0,\infty) is a point of continuity of f.
I know I need to show that
<br /> f(y) = \lim_{h\to 0} \int_y^{y+h} \frac{1}{h} f(t) dt.<br />
My idea was to try to do this in terms of sequences; i.e., to let \{h_n\} be any sequence of real numbers such that h_n \to 0, and then to phrase the limit above in terms of a limit as n\to \infty. I had then planned to use something like the dominated convergence theorem. But I don't have any idea how to make use of the hypothesis that f is continuous at y, so I'm not sure if this is the right approach.
could you look at it as follows:
f(y) = \lim_{h\to 0} \frac{1}{h} \int_y^{y+h} f(t) dt
then use the conitinuity of f to show that as h gets small
\int_y^{y+h} f(t) dt \approx f(t).h
Ok. I think I know how to do this. Here is a complete solution: Let f \in L^1(\mathbb R). We want to show that, given any \epsilon &gt; 0, we can find a \delta &gt; 0 such that
<br /> \left| \frac{1}{h} \int_y^{y+h} f - f(y) \right| &lt; \epsilon<br />
whenever |h| &lt; \delta. Since f is continuous at y, we know we can find a \delta such that |t - y| &lt; \delta implies |f(t) - f(y)| &lt; \epsilon. So, if we make |h| &lt; \delta, we have
<br /> \begin{align*}<br /> \left| \frac{1}{h} \int_y^{y+h} f - f(y) \frac{1}{h} \int_y^{y+h} f \right|<br /> &amp; \leq \frac{1}{h} \int_y^{y+h} \left| f(t) - f(y) \right| dt\\<br /> &amp; \leq \frac{1}{h} \int_y^{y+h} \epsilon dt = \epsilon.<br /> \end{align*}<br />
That does it, I think.
There is a typo, you should write:
<br /> \left| \frac{1}{h} \int_y^{y+h} f - f(y) \right| =\Bigg|\frac{1}{h}\int_{y}^{y+h}f-f(y)\int_{y}^{y+h}\frac{1}{h}\Bigg|<br />
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
