Differentiation concept problem
quietrain
i am suddenly stuck when differentiating. are my concepts right?
if we integrate cosx/sinx, then since cosx is the differentiated form of sinx, then integrating d(sinx)/sinx = ln|sinx|
so now, if i have : integrate z/(1-z2)1/2
since z is the differentiated form of the denominator(barring the minus sign), (1-z2)1/2,
then integrating d((1-z2)1/2)/(1-z2)1/2,
shouldn't i get ln (1-z2)1/2 ? but the answer is without the ln, and true enough when i try to differentiate the ln (1-z2)1/2, i don't get back my original function.
so where did i go wrong?
thanks!
It's definitely true that \displaystyle \int\frac{d(\sqrt{1-z^2})}{\sqrt{1-z^2}}=\ln|\sqrt{1-z^2}|+C
But notice that \displaystyle d(\sqrt{1-z^2})=-\frac{z}{\sqrt{1-z^2}}dz\,.
So, \displaystyle \int\frac{d(\sqrt{1-z^2})}{\sqrt{1-z^2}}=-\int\frac{z\,dz}{\sqrt{1-z^2}}\,.
er i don't quite follow what you are saying?
the answer given for \int\frac{z\,dz}{\sqrt{1-z^2}}\,. is just - (1-z2)1/2
if i understand what you are saying, you are implying that the answer should be ln(1-z2)1/2
oh i see what you are trying to say.
just that i think you have a typo at the last expression
thanks!
thanks!
Let's see:
\displaystyle \frac{d}{dz}(\sqrt{1-z^2})=-\frac{z}{\sqrt{1-z^2}}\,.
So, the last one seems right.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
