Differentiation - finding equation of normal to curve
studentxlol
Find the equation of the normal to the curve y=(6x+3)^(1/2) at the point for which x=13.
dy/dx=dy/du*du/dx
y-y1=m(x-x1)
y=(6x+3)^(1/2)
dy/dx=1/3(6x+3)^2
gradient of normal = -3(6x+3)^2
at x=13, dy/dx=-3(6x13+3)^2=19683.
obviously a silly answer and the textbook disagrees.
So at this point I could simplify y=(6x+3)^(1/2) to y=(2x+1)^2 maybe? Even after doing this, I end up with an even slightly smaller silly answer and the textbook still disagrees, unless the textbook is wrong, although this is highly unlikely.
HELP!
You will want to start by checking this:
studentxlol said:
dy/dx=1/3(6x+3)^2
I inputted y=(6x+3)^(1/2) into wolfram alpha and the answer came out to be:
√3/(2x+1)^(1/2)
I'm confused. I used the chain rule to get:
subu=6x+3 so that y=u^1/2
dy/du=1/2u^-(1/2)=1/2(6x+3)^-(1/2) and du/dx=6
=> dy/dx=dy/du*du/dx=3(6x+3)^-(1/2).
Work out the derivative by hand. It's straightforward.
I put that into WolframAlpha and got the correct answer.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
