Differentiation of cells in an embryo
Embryo cell differentiation typically begins at implantation, with blastocysts already on a differentiation path. Some research suggests that differentiation may start as early as the first cell division, as cells must understand their positional information for proper body development. This is likely regulated by mechanisms that control gene expression. In vertebrates, differentiation does not occur until after the 8-cell stage, allowing for the potential formation of twins if the embryo splits. The lack of differentiation before this stage may be due to a transcriptionally repressive state during the 2-cell stage, which inhibits gene expression. The surrounding cellular environment and competition among cells also play crucial roles in determining differentiation pathways. Conjoined twins arise from incomplete splitting of the embryo around the 8-cell stage, leading to mirrored development patterns. Understanding these processes requires a deeper exploration of developmental biology and cellular communication.
sontag
Can embryo cells start to differentiate before the embryo
is implanted in the uterus? The differentiation usually starts
at the time of implantation.
Biology news on Phys.org
Blastocysts are implanted, these are already on their path of differentiation (trophoblast/inner cell mass).
Embryoes likely begin differentiating with the first division. In order for areas of the body to develop in the appropriate position on the body the cells need to know their position in the body. This would most likely be accomplished by cells initially having a mechanism to turn groups of genes on or off so that they develop for the appropriate portion of the body.
Some research indicates that embryonic cells cannot each develop into all different cells. For example, an experiment to develop heart cells had to rely on watching for some of the embryonic cells in a dish to develop into cells that acted like heart cells.
http://www.washingtonpost.com/wp-dyn/articles/A52471-2004Sep26.html
In vertebrates, the cells do not begin differentiating until after the 8-cell stage. Up until this point, the embryo could split in half and form twins.
What stops cells differentiating in vertebrates before the 8 cell stage?
VERY good question :) I'm not sure if there is a definative answer to that. Schultz et. al. (1999) proposed that a transcriptionally repressive state develops during the 2-cell stage (that transforms highly differentiated oocytes into totipotent blastomeres), where an increased histone deacetylation represses transcription.
The whole transcription machinery needs to be started again, which is sensitive to signals from the cells it is surrounded with. For me it is speculation what exactly happens at these very early stages, probably it is competition where the cells are competing against chemokines excreted by the others, when one cell takes the overhand it starts producing negative regulatory proteins that inhibit the other cells to differentiate in the same way. This then sets off a cascade that triggers the other cells to undertake other developmental routes.
You can read up on developmental biology to understand exactly how cells communicate are able to create complex architectures.
If no differentiation occurs, how do you explain conjoined twins? they develop as mirror images connected at different locations, typically the torso or head, and occasionally share organs. Something in the programming causes both to develop heads at the same end and feet at the same end, unless you know of cases in which one develops upside down compared to the other.
That is the whole point: you get conjoined twins if the egg incompletely splits around the 8-cell stage (not sure exactly what the time window is).
