Difficult function of a function problem
  • Thread starter Thread starter contempquant
    Function
The discussion revolves around a problem involving the differentiation of a function of a function, specifically focusing on the double derivative of a function defined as E(𝑟) = E₀(𝑟)e^(ikz), where 𝑟 is a function of z. Participants are exploring the application of the chain rule in this context.
  • The original poster attempts to differentiate the function using the chain rule but expresses uncertainty about how to handle the partial derivatives due to the dependency of 𝑟 on z. Other participants suggest using the chain rule and question the definition of 𝑟, considering its implications on the differentiation process.
Participants are actively engaging with the problem, with some offering insights into the differentiation process and questioning the notation used in the original problem statement. There is an acknowledgment of potential ambiguity in the definitions provided in the source material, leading to further exploration of the assumptions involved.
There is a noted lack of clarity regarding the definition of 𝑟 in the context of the problem, as it is not explicitly defined in the referenced textbook. This has led to varying interpretations of how E₀ should be treated in relation to its variables.
contempquant
I'm trying to solve a double derivative of a function of a function problem, but can't seem to be able to differentiate once. I have the formula given by the chain rule,
find [tex]\frac{d}{dz}{E}(\bar{r})[/tex] when [tex]{E}(\bar{r})={E_0}(\bar{r})e^{ikz}[/tex] and [tex]\bar{r}[/tex] is a function of z.
I have used [tex]\frac{df}{dz}=\frac{dg}{df}\frac{df}{dz}h(x)+\frac{dh}{df}\frac{df}{dz}g(x)[/tex]
where [tex]g(x)={E_0}(\bar{r})[/tex] and [tex]h(x)=e^{ikz}[/tex]
and [tex]f=E(\bar{r})=E_{0}(\bar{r})[/tex]
I have then substituted in for these giving,
[tex]\frac{d{E_0}(\bar{r})exp^{ikz}}{dz}[/tex]=[tex]\frac{\partial{E_0}(\bar{r})}{\partial{E}(\bar{r})}\frac{\partial{E}(\bar{r})}{\partial{z}}*e^{ikz}+\frac{\partial{e^{ikz}}}{\partial{E}(\bar{r})}\frac{\partial{E}(\bar{r})}{\partial{z}}*E_{0}(\bar{r})[/tex]
The problem is i don't know how to differentiate any of the individual partial differentials because [tex]\bar{r}=r(z)[/tex], r is dependent on z. Any ideas? i really don't know how to start this one, and when this is done i have to differentiate it again. I'm sure if i can find out how to do this once i can do the second derivative but can't seem to do this one.
apparently the final solution is,
[tex](\frac{\partial^{2}E_{0}}{\partial{z}^{2}}+2ik\frac{\partial{E_0}}{\partial{z}}-k^{2}E_0)e^{ikz}[/tex]
anyone?
So in [tex]\mathbf{r}=x\mathbf{i}+y\mathbf{j}+z\mathbf{i}[/tex] and [tex]r=\sqrt{x^{2}+y^{2}+z^{2}}[/tex] then you use the chain rule in the following way:
[tex] \frac{d}{dz}E_{0}(r)=\frac{dE_{0}}{dr}\frac{dr}{dz}[/tex]
sorry, that third line under relevant equations: [tex]f=E(\bar{r})=E_{0}(\bar{r})[/tex]
should read
[tex]f=E(\bar{r})=E_{0}(\bar{r})e^{ikz}[/tex]
I think that might change the answer you gave hunt_mat?
define [tex]\bar{r}[/tex] for me.
well that's the thing because [tex]\bar{r}[/tex] isn't defined in the book (Milonni, Lasers) but only the scalar version of r is defined, which is as you wrote it above,
[tex]r=\sqrt{x^{2}+y^{2}+R^{2}}[/tex]
Where [tex]z=R[/tex], R is the distance along the z axis
So this r is a vector? I think that either you can take E_0 as a function of x, y, and z or that it only has radial dependence.
so the differential of [tex]\frac{\partial{E_0}(\bar{r})}{\partial{Z}[/tex] is just one?
how do i do the differential,
[tex]\frac{\partial{E_0}(\bar{r})}{\partial{E}(\bar{r}) }[/tex]? as it's taken w.r.t the starting function?
* [tex]\frac{\partial{E_0}(\bar{r})}{\partial{Z}}[/tex]
I think that may be the case, having had a little look at the book on amazon, it seems like it's poor notation. I think the notation means that E_0 is a function of x,y and z and you just write down: the derivative as you have, that is how I would view the problem.
ok i'll try that, thanks
  • · Replies 19 ·
