How can I convert the units of B to match the Kennicutt Schimdt law?
  • Thread starter Thread starter matteo86bo
    Units
The discussion focuses on converting the units of the parameter B in the context of the Kennicutt-Schmidt law, which relates star formation efficiency to gas and stellar surface densities. The user attempts to derive B from a volumetric star formation law and expresses concern over unit discrepancies when comparing it to the Kennicutt-Schmidt law's efficiency parameter A. They suggest that B should be dimensionless, but their calculation involving B and a characteristic scale length leads to confusion regarding its units. The conversation highlights the need for clarity in unit conversion and dimensional analysis to ensure consistency between the two laws. Ultimately, the user seeks assistance in resolving these unit conversion issues.
matteo86bo
I need to infer the observed star formation efficiency of the Kennicutt Schimdt law starting from a volumetric SF law.
The KS law is a relationship between gas and stellar surface density that we can approximate as:
\frac{d\Sigma_*}{dt}=A\Sigma_{gas}^{1.5}
Where A is the efficiency and its values is roughly 2.5e-4 when \frac{d\Sigma_*}{dt} is measured in M_\odot kpc^{-2} yr^{-1} and \Sigma_{gas} in M_\odot pc^{-2}.
Now the problem is I want to derive this efficiency starting from this formula
\frac{d\rho_*}{dt}=B\frac{\rho_{gas}}{t_{ff}}
where {t_{ff}} is the free-falling time and is equal to
{t_{ff}}=\sqrt{\frac{3}{32\pi G \rho_{gas}}}
I need to compute B and then convert it in the same units of the Kennicutt Schimdt law.
2. The attempt at a solution
Since the Kennicutt law involes surface density I have multiplied both sides of the volumetric equation by a characteristic scale length \Delta x.
Therefore B should be equal to:
\sqrt{\frac{32\pi G}{3}} \Delta x
The things is I had to convert this number from cgs units to the units in which the Kennicutt law is given but I don't get the same order of magnitude. Can you help me?
I gave this a shot, but it turns out I'm less able than you are at solving this. I would re-post this question in the Advanced forum if no one else here helps you soon.
Let's see if the units are making sense first:
For \frac{d\rho_*}{dt}=B\frac{\rho_{gas}}{t_{ff}} ,
we have M_\odot pc^{-3} yr^{-1} on the left and
B times M_\odot pc^{-3} divided by years on the right , so B should be dimensionless, no? (I'm taking it that the rho's are volume densities.)
So I don't think B = \sqrt{\frac{32\pi G}{3}} \Delta x can be right.(And A has units of \frac{pc }{ M_\odot^{1/2}\cdot yr} ,yes? )
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
