Diffraction Grating and Dispersion
A diffraction grating with a slit separation of 2094.0 nm is analyzed for the dispersion of its 2nd order lines at a 30-degree angle. The initial confusion arose from incorrect calculations of wavelength and the need for the correct dispersion equation. The correct formula for dispersion is D = m/(d cosΘ), leading to a calculated dispersion of 1.10 degrees per micrometer. The discussion emphasizes the importance of using the right equations and understanding the relationship between angle and wavelength. Ultimately, the key takeaway is mastering the mathematical relationships in diffraction to solve such problems effectively.
lauraliz94
1. The problem statement
A diffraction grating has a slit separation of 2094.0 nm. What is the dispersion of the 2nd order lines at an angle of 30 degrees (in degrees per micrometer)?
dsinΘ=mλ
y=(mDλ)/d
3. Attempt at a solution
I began by finding λ using the first equation, so...
2λ=.002094(sin(.30))
λ=.00000548205
Note: I changed d from nm to mm before I began any calculations
We haven't gone over this in class yet, so I'm confused on where to go from here. I believe it has something to do with the second equation listed above, but I don't know what variable represents the dispersion or if these are really even the equations I need. I would like some guidance as for what steps to take next or what equations I should be using- I think just a push in the right direction could help immensely.
Hello LL, welcome to PF :)
Check your calculations ! sin(.30) is not the sine of 30 degrees ! I don't see how you can end up with 5.5 nm wavelength (assuming you report it in mm -- why do you do that if they want an answer in degrees per micrometer ?).
And the angular dispersion is nothing else than ##d\theta\over d\lambda##.
So you're better off with the first eqn than with the second (that is -- if I am not mistaken -- a distance y off-axis on a screen at distance D).
Now, what is ##d\theta\over d\lambda## at ##\ \ \theta = \pi/6\ \ ## if ## \ d\sin\theta = 2\lambda\ ## ?
It's more math than physics...
Hi BvU!
Alright, I was able to work on the problem in class- I was missing a vital equation that made the whole process really easy.
The equation should be D=m/(d)cosΘ
So if...
D=dispersion
m=2
d=2.094 micrometers
Θ=30 degrees
Then the equation reads...
D=(2)/(2.094cos(30))
D=1.10 deg/micrometer
I'm sorry about the confusion, I really appreciated your help! You were right, it was just figuring out what math is the right math!
And here's me thinking you were supposed to derive this vital equation. You were nearly there!
The "math" (physicists have their own ideas about how to deal with differentials :) ) is real easy: $$
\ d\sin\theta = 2\lambda\quad\Rightarrow\ d \cos\theta \; d\theta = 2\; d\lambda\quad \Rightarrow\ {d\theta\over d\lambda} = {2\over d\cos\theta}$$
