Diffraction wavelength of particles in moving frames?
knowing
Here's a question I cannot seem to comply with my understanding of Quantum Mechanics.
The characteristic wavelength of a particle is responsible for diffraction interference fringes, which is part of the wavefunction solution to the schrodinger equation. But the wavelength of a particle is dependent on its momentum P. So if the whole diffraction experiment was carried out in a moving frame of reference, then by the unitary space-time translating operator G, which translates the velocity, the momentum is dependent on the frame of reference. So in the moving frame of reference, the particle would seem to have a different wavelength. So what wavelength would the diffraction pattern relate to, which I assume must give the same fringe pattern in both frames.
In the moving frame the diffraction grating or slit will also be moving, which will complicate the calculation of the diffraction pattern. Once you account for this, the result of the calculation will be the same diffraction pattern as you would calculate in the original frame.
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. Towards the end of the first lecture for the Qiskit Global Summer School 2025, Foundations of Quantum Mechanics, Olivia Lanes (Global Lead, Content and Education IBM) stated... Source: https://www.physicsforums.com/insights/quantum-entanglement-is-a-kinematic-fact-not-a-dynamical-effect/ by @RUTA
If we release an electron around a positively charged sphere, the initial state of electron is a linear combination of Hydrogen-like states. According to quantum mechanics, evolution of time would not change this initial state because the potential is time independent. However, classically we expect the electron to collide with the sphere. So, it seems that the quantum and classics predict different behaviours!
