Diluting the stock solution with ethanol
  • Thread starter Thread starter physicsss
    Ethanol
The discussion focuses on calculating the concentration of a diluted stock solution of sunscreen in ethanol. The initial line provides a concentration of 0.0898 g/mL for the stock solution. The dilution factor is defined as the ratio of the volume of the stock solution to the total volume after dilution. For example, in the second row, the dilution factor is calculated as 2.5 mL (stock) divided by the total volume of 3.0 mL, resulting in a dilution factor of 1:1.2. To find the concentrations for the missing entries (X and Y), one can use the formula V1C1=V2C2, where V1 is the volume of the stock solution, C1 is its concentration, V2 is the total volume, and C2 is the concentration after dilution. By applying this method, the concentrations can be determined based on the known values and the defined dilution factors.
physicsss
mL stock solution___mL95% Ethanol____Dilution factor____g/mL
3.00______________0.00_____________1:1_____________0.0898
2.50______________0.50_____________1:1.2___________X
2.00______________1.00_____________1:1.5___________Y
I think the idea is you are diluting the stock solution with ethanol...how do I calculate how much the concentration is in the solution X and Y?
ignore those lines...I had to use those to line the data up.
Chemistry news on Phys.org
What is the definition of the concentration ? And what does the first line tell you ? And how do you think the dilution factor is defined ?
You ought to show some effort before asking for help, physicsss.
All I'm given is that V1C1=V2C2..., but the volume adds up to 3.0mL. I don't know what the dilution factor means.
Can you write down the question EXACTLY as it appears in your homework/text ?
Okay, that's fine.
Notice that by the definition of dilution factor (volume of stock / total volume), the numbers in the first two colums are consistent with the numbers in the third column.
Example : (row 2) DF = 2.5/(2.5 + 0.5) = 2.5/3 = 1/1.2
In this manner you can calculate the DF for other rows.
The first row tells you the concentration of sunscreen in the stock (.0898 g/mL). Knowing how much sunscreen there is in 1 mL, you can then find out how much there will be in 2.5 mL, 2 mL, 1.5 mL, etc. (the volumes of the different stock solutions). Dividing these weights by the total volume gives you the concentration for each case.
I want to test a humidity sensor with one or more saturated salt solutions. The table salt that I have on hand contains one of two anticaking agents, calcium silicate or sodium aluminosilicate. Will the presence of either of these additives (or iodine for that matter) significantly affect the equilibrium humidity? I searched and all the how-to-do-it guides did not address this question. One research paper I found reported that at 1.5% w/w calcium silicate increased the deliquescent point by...
