What is the dimension of the impulse response of an electric circuit?
The impulse response h(t) of an electric circuit is the derivative of the step response s(t), suggesting they have different dimensions. If the dimension of s(t) is X, then h(t) has the dimension of X per second. For a system where the output dimension matches the input dimension, the convolution integral requires that the dimension of h(t) cancels the time dimension associated with du. Consequently, h(t) must have the dimension of the reciprocal of time. Understanding these relationships is crucial for analyzing electric circuit responses.
asmani
Hi all
The impulse response h(t) of an electric circuit (maybe in some special cases) is the derivative of the step response s(t) of the same circuit. right?
So does it mean they have different dimension, namely if the dimension of s(t) is X, then the dimension of h(t)=ds/dt is x over second?
Thanks in advance.
okay, let's say that your impulse response is for a device in which the dimension of the output is the same as the dimension of the input. like voltage-in, voltage-out (but it could be current in/out or something else).
then, for the convolution integral to work
y(t) = \int_{-\infty}^{+\infty} h(t-u) x(u) du = \int_{-\infty}^{+\infty} h(u) x(t-u) du
the dimension for h(t) must cancel the dimension of the du which we normally attach to "time". so the dimension of h(t) is the reciprocal of time.
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
