Dimensional analysis, conversion of units in an equation
The discussion centers on the dimensional analysis and unit conversion of the equation h=1147(1+0.05625T)(V^{0.6}/D^{0.4}) from units of kcal to Btu, and from Celsius to Fahrenheit. The correct conversion factors include 1 Btu = 0.252 kcal, 1 ft = 0.3048 m, and the temperature conversion for differences is 1 ºC = 1.8 ºF. The final transformed equation is h=2.479T(V^{0.6}/D^{0.4}), with the professor asserting the necessity of using the temperature difference conversion rather than the absolute temperature conversion.
  • Understanding of dimensional analysis
  • Familiarity with unit conversion techniques
  • Knowledge of temperature conversion formulas
  • Basic algebra for manipulating equations
  • Study dimensional analysis principles in engineering contexts
  • Learn about unit conversion methods in thermodynamics
  • Explore temperature conversion and its implications in equations
  • Investigate common pitfalls in unit conversions and dimensional homogeneity
Students in engineering or physics, educators teaching dimensional analysis, and professionals involved in thermodynamic calculations will benefit from this discussion.
tkfn
We are asked to transform this equation:
h=1147(1+0.05625T)[itex]\frac{V^{0.6}}{D^{0.4}}[/itex]
where the units of each variable h, T, V and D are:
h->[itex]\frac{kcal}{h·m^{2}·ºC}[/itex]
T->ºC
V->[itex]\frac{m}{s}[/itex]
D->cm
into another equation where the units of each variable h, T, V and D now are:
h->[itex]\frac{Btu}{h·ft^{2}·ºF}[/itex]
T->ºF
V->[itex]\frac{ft}{s}[/itex]
D->inches
Data:
1 Btu <> 0.252 kcal
1 ft <> 0.3048m
1 ft <> 12 inches
1 ºC <> 1.8 ºF
(ºF) = 1.8(ºC)+32
The professor said the solution is
h=2.479T[itex]\frac{V^{0.6}}{D^{0.4}}[/itex]
however I've tried the very same solution method which had worked for me in the past to solve other conversion problems but I can't seem to get the answer right, I'm confused as to which temperature conversion "factor" should we use, 1 ºC<>1.8 ºF or (ºF)=1.8(ºC)+32? I have really given up on this. :confused:
Show your work.
In your unit conversions, you have something per degree C. You are not trying to find a particular temperature, so F = 1.8C + 32 is not the correct conversion.
Well what i did first is find out the units of the constant 1147 in the original equation so the principle of dimensional homogeneity at both sides of the = sign is satisfied:
[itex]\frac{kcal}{h·m^{2}·ºC}[/itex]=[itex]\frac{kcal·cm^{0.4}·s^{0.6}}{h·m^{2.6}·ºC^{2}}[/itex]·ºC·[itex]\frac{m^{0.6}}{cm^{0.4}·s^{0.6}}[/itex]
Then I repeated the same process for the units of the new desired equation:
[itex]\frac{Btu}{h·ft^{2}·ºF}[/itex]=[itex]\frac{Btu·inches^{0.4}·s^{0.6}}{h·ft^{2.6}·ºF^{2}}[/itex]·ºF·[itex]\frac{ft^{0.6}}{inch^{0.4}·s^{0.6}}[/itex]
Then I made an attempt to convert the constant with its units from the original equation into a constant with the units from the desired equation:
1147[itex]\frac{kcal·cm^{0.4}·s^{0.6}}{h·m^{2.6}·ºC^{2}}[/itex]·[itex]\frac{Btu}{0.252kcal}[/itex]·[itex]\frac{0.394^{0.4}inches^{0.4}}{cm^{0.4}}[/itex]·[itex]\frac{0.3048^{2.6}m^{2.6}}{ft^{2.6}}[/itex]· This is where I don't know how to proceed in order to convert the temperature units from ºC[itex]^{2}[/itex] to ºF[itex]^{2}[/itex], the professor said we should use the factor 1ºC <> 1.8ºF when we have ΔT in an equation BUT when we have a specified T we should use (ºF)=1.8(ºC)+32, but SteamKing disagrees so I don't know how to proceed at all. I have a hunch my professor made a mistake but I'm not sure.
  • · Replies 23 ·
