How does dimensional analysis account for additive variables in equations?
Dimensional analysis primarily relates dependent variables to independent variables through multiplicative relationships, but it struggles with additive variables. The method does not inherently accommodate operations like addition or subtraction, which can complicate the derivation of accurate equations. When multiple independent expressions are involved, such as in cases with two velocities or masses, dimensional analysis alone cannot determine the appropriate variable to use. This limitation highlights the need for additional mathematical techniques beyond dimensional analysis to address additive components in equations. Therefore, while dimensional analysis is useful, it cannot fully account for all scenarios involving additive variables.
Mr Davis 97
Under the standard form of dimensional analysis, I know that we relate a dependent variable to a function of the independent variable(s). However, what if there is some additive variable needed in the equation? How does this method, which expresses all of the independent variables as a product of the variables (with the exponents being any real number) times a constant, account for the needed addition of operations such as subtraction and addition? How can we derive correct equations if there is a missing sum or difference needed in the formula?
If you can construct a specific unit with multiple independent expressions, then dimensional analysis for this unit does not work.
A trivial example is a setup where you have two velocities, or two masses or something similar. There is no way to figure out which velocity/mass/... to use just by dimensional analysis.
So I know that electrons are fundamental, there's no 'material' that makes them up, it's like talking about a colour itself rather than a car or a flower. Now protons and neutrons and quarks and whatever other stuff is there fundamentally, I want someone to kind of teach me these, I have a lot of questions that books might not give the answer in the way I understand. Thanks
