Dipole Oscillation: Solving for Period
In summary, the homework statement is that:-Homework Equations state that Frsin(\theta) = I \alpha -I=mr^2 -F=QE -Simplifying yields QEsin(\theta)A=-\frac{1}{2}MA^2 \frac{d^2\theta}{dt^2}-If the torque is negative, alpha is negative and vice versa. -The equation for simple harmonic motion is \frac{d^2\theta}{dt^2} + {\omega}_0^2\theta = 0.
indigojoker
246
#3 on this PDF
[tex] \tau = Frsin(\theta) = I \alpha [/tex]
[tex] I=mr^2 [/tex]
Here's what I've done:
[tex]F=QE[/tex]
[tex] 2QEsin(\theta) \frac{A}{2} = 2M\left(\frac{A}{2}\right)^2 \alpha [/tex]
simplify:
[tex] QEsin(\theta)A = \frac{1}{2}MA^2 \frac{d^2\theta}{dt^2} [/tex]
[tex]\frac{d^2\theta}{dt^2} - \left(\frac{2QE}{MA}\right) \theta = 0[/tex]
I'm not sure how to get the period.
I know that [tex]\omega = 2 \pi \frac{1}{T} [/tex]
but I'm stuck here. Any help would be much appreciated.
You're almost there... [tex]\alpha[/tex] here equals [tex]-\frac{d^2\theta}{dt^2}[/tex]
once you fix that your equation is of the form:
[tex]\frac{d^2\theta}{dt^2} + {\omega}_0^2\theta = 0[/tex]
so you can get [tex]{\omega}_0[/tex]
why is alpha negative?
and is the form [tex]\frac{d^2\theta}{dt^2} + {\omega}_0^2\theta = 0[/tex] standard?
where did this equation come from?
also, how would i show the system to have small oscillations?
The way you calculate torque... it is acting clockwise... therefore [tex]\alpha[/tex] should be the angular acceleration in the clockwise direction... however as the object turns clockwise, your theta angle decreases... examine what happens to theta as the object rotates in the direction of the torque...
Yes, it is the standard equation for a harmonic oscillator.
The question asks you to assume small oscillations. ie approximate sin(theta) as theta... as you did.
I'm sorry, i did not mean to ask about small oscillations, I was wondering more about how to show the system exhibits simple harmonic motion, before ever going to get the period of oscillation.
and the torque will sometimes be negative, and sometimes be positive. How do you know alpha is negative?
The fact that the equation is in this form for small theta:
shows that there's simple harmonic motion...
As for the torque... let me ask this... what angle is [tex]\theta[/tex]... and how does it change with positive torque... how does it change with negative torque...
when the torque is positive [tex]\alpha[/tex] should be positive... when the torque is negative [tex]\alpha[/tex] should be negative.
right, so by saying [tex]-\frac{d^2\theta}{dt^2}[/tex]
this means the torque is always negative, but it isn't is it?
No, not when [tex]\frac{d^2\theta}{dt^2}[/tex] is negative...
i'm just really dense right now. I still don't know why you would need a negative sign.
could you explain it differently? I'm not seeing the whole picture
let's put this problem aside and look at a different one... suppose I have a wrench on the ground connected to some pivot... the wrench forms an angle of let's 45 degrees with the east axis... so theta is 45. Let's say the wrench is 0.5m. I exert a force of 10N at the end of the wrench... eastward...
What is the torque about the pivot?
T=.5*10*sin45
indigojoker said:
T=.5*10*sin45
cool. now is [tex]\frac{d^2\theta}{dt^2}[/tex] positive or negative here? taking theta as the angle made with the east axis...
angle is decreasing so it's negative?
Yes... the angular acceleration is clockwise... in other words the angle the wrench makes with the vertical... call it [tex]\alpha[/tex]... [tex]\frac{d^2\alpha}{dt^2}[/tex] is positive... theta = 90 - alpha... [tex]\frac{d^2\theta}{dt^2} = -\frac{d^2\alpha}{dt^2}[/tex]
You found the torque clockwise... but [tex]\frac{d^2\theta}{dt^2}[/tex] is the counterclockwise angular acceleration...
you could have done the opposite and found the torque counterclockwise... and said T=-.5*10*sin45 (that's the counterclockwise torque)... now in this case you can say [tex]T = I\frac{d^2\theta}{dt^2}[/tex]... but since you said T = +0.5*10*sin45 which is the clockwise torque... you must say [tex]T = -I\frac{d^2\theta}{dt^2}[/tex]
so say we assumed the counter clockwise notation for the torque for the question for the dipole-dumbbells. so [tex]T = I\frac{d^2\theta}{dt^2}[/tex]
then I would still get:
[tex]\frac{d^2\theta}{dt^2} - {\omega}^2\theta = 0[/tex]
no, because then
[tex]T = - 2QEsin(\theta) \frac{A}{2} [/tex] in order for torque to be counterclocwise.
ok sure, the wrench is fixed and applying a torque will always rotate it clockwise, however, the dipole-dumbbell rotates both clockwise and counterclockwise. This means that that torque can be negative and positive even if we took a clockwise/counterclockwise notation. Since it's not just going in a circle, why would alpha be negative inthe clockwise notation then?
It's not about whether the torque turns out clockwise or counterclockwise... torque is actually a vector... it has a magnitude and a direction... one way we deal with the direction is by using clockwise... counterclockwise...
It is just like with vectors... suppose I have an object with just one force acting on it is labelled F with an arrow to the right... but F could be a negative number... in which case the force is actually acting towards the left... F is the force acting to the right... but it could be negative...
Now suppose I label the acceleration to the left a... I have a with an arrow pointed to the left... again a itself can be positive or negative... if a is negative then the acceleration is actually to the right... a is the acceleration to the left... but a could be negative...
What is the relationship between F and a here given a mass m?
ok, could you tell me if this explanation looks right?
http://home.earthlink.net/~suburban-xrisis/phy.pdf
Seems like you're mixing up clockwise and counterclockwise...
Do you agree that [tex]\frac{d^2\theta}{dt^2}[/tex] is the counterclockwise angular acceleration? because counterclockwise is the direction of increasing theta...
oh whoops you're right, wait so if we took the fact that clockwise is positive torque, then wouldn't alpha be positive instead of negative?
wait, hold on, I think i know why... give me a second to post up another pdf.
please visit the same link again:
For the second part... instead of calling the angle - theta, I'd rather call the angle as still being theta but where theta happens to be negative...
So in both cases... clockwise torque = -I[tex]\frac{d^2\theta}{dt^2}[/tex]
In both cases counterclockwise torque = I[tex]\frac{d^2\theta}{dt^2}[/tex]
you can pick either convention... makes no difference...
in the second case where theta is negative, [tex]\frac{d^2\theta}{dt^2}[/tex] > 0 in the first case it is less than 0... but the equations remain the same...
cool. So why would [tex] \tau = -Frsin(\theta) [/tex] when taking the counterclockwise torque notation?
well... that's how the torque is defined... suppose F is positive, sin(theta) is positive... what is the direction the object is trying to move... clockwise... the torque is a positive value clockwise... hence it is a negative value counterclockwise... and checking the formula -Frsin(theta)... give a negative value... so it works...
F negative, sin(theta) positive... now the object is trying to move counterclockwise... hence the counterclockwise torque should be positive... -Frsin(theta) is positive here... again the formula works...
Examine all combinations of F (positive or negative) and sin(theta) positive and negative... examine which way the torque is... see if the formula -Frsintheta works or not for counterclockwise torque...
If instead you choose F as being the force acting to the left... then everything switches signs... but since you chose F as being to the right,this is how the formulas turn out.
it seems like the torque really depends on how theta is defined. If theta was along the vertical, then alpha would be positive.
by the way, this might be overkill but could you check my explanation? I just want to make sure what I have makes sense:
I'm sorry indigo... still finding that last section confusing... as I'm sure my explanations are confusing to you...
Why do you have the force on the dipole downwards, then upwards... in both cases, the force should be towards the right in the direction of E.
sorry, those are the y-componets since the y-componets is the force that the torque considers.
  • #31
But there is no y-component... I think you mean the component perpendicular to the dipole line?
It is easier to take torque here as the force (horizontal)... times the perpendicular distance from the axis of rotation to the line of force... ie rsintheta is the perpendicular distance the the line of force (where the force is horizontal)... hence torque if Frsin(theta)...
  • #32
yeah, i mean the F in my drawing is =rsintheta
does my explanation in the pdf make more sense now?
  • #33
I'm still finding it confusing... stick with a particular definition for alpha and theta... for example alpha as the clockwise angular acceleration... theta is the angle measured from the positive x-axis... taking positive as counterclockwise... negative as counterclockwise...
Define theta and alpha in a certain way of your choosing... but then stick with that...
Same way... stick with a particular direction for torque... ie clockwise positive, counterclockwise negative...
with the definitions I chose above (alpha clockwise angular acceleration... theta measured from positive x-axis counterclockwise):
clockwise torque = I* alpha, and alpha = [tex]-\frac{d^2\theta}{dt^2}[/tex]
these two definitions don't change...
in the first case clockwise torque =Frsin(theta).
in the second case also, clockwise torque = Frsin(theta) (see sintheta is negative because theta is negative... and the number comes out negative because it's rotating the other way... but it is still the clockwise torque... the clockwise torque comes out negative... counterclockwise torque is positive).
The definitions don't change... the equations don't change... the numbers come out different but the relationships remain the same...
  • #34
ok, let's see if i understood it this time:
  • #35
The first part looks essentially right... but I don't like how you just went from torque = -I[tex]\frac{d^2\theta}{dt^2}[/tex] to substituting in [tex]-\frac{d^2\theta}{dt^2}[/tex] for [tex]\frac{d^2\theta}{dt^2}[/tex]
I think it's better to just say that since [tex]\frac{d^2\theta}{dt^2}[/tex] is negative, torque = -I[tex]\frac{d^2\theta}{dt^2}[/tex] comes out positive... which is consistent with the torque being clockwise.
For the second part, I'd just write torque = -I[tex]\frac{d^2\theta}{dt^2}[/tex], is still valid... because [tex]\frac{d^2\theta}{dt^2}[/tex] is positive... giving a negative value for the torque... and this is consistent with the fact that torque is counterclockwise here... so we expect a negative value.
1. What is a dipole oscillation?
A dipole oscillation is a type of oscillation or vibration that occurs when an electric dipole is placed in an electric field. It is characterized by the back-and-forth motion of the dipole as it experiences a changing electric field.
2. How is the period of a dipole oscillation calculated?
The period of a dipole oscillation can be calculated using the equation T = 2π√(I/k), where T is the period, I is the moment of inertia of the dipole, and k is the restoring force constant of the electric field.
3. What factors can affect the period of a dipole oscillation?
The period of a dipole oscillation can be affected by the strength of the electric field, the moment of inertia of the dipole, and the restoring force constant of the electric field.
4. How does the period of a dipole oscillation change with the strength of the electric field?
The period of a dipole oscillation is directly proportional to the strength of the electric field. As the electric field becomes stronger, the period of the oscillation decreases.
5. Can the period of a dipole oscillation be changed by adjusting the moment of inertia?
Yes, the period of a dipole oscillation can be changed by adjusting the moment of inertia. A larger moment of inertia will result in a longer period, while a smaller moment of inertia will result in a shorter period.
