Dirac notation Schwarz Inequality Proof
6 replies · 9K views · last reply
interdinghy
This isn't really a problem so much as me not being able to see how a proof has proceeded. I've only just today learned about Dirac notation so I'm not too good at actually working with it. The proof in the book is:
|Z> = |V> - <W|V>/|W|^2|W>
<Z|Z> = <V - ( <W|V>/|W|^2 ) W| V - ( <W|V>/|W|^2 ) W> =
<V|V> - ( <W|V><V|W>/|W|^2 ) - ( <W|V>*<W|V>/|W|^2 ) + ( <W|V>*<W|V><W|W>/|W|^4| ) >= 0
This last step has me completely lost, and if someone could explain it I'd really appreciate it. It looks like he's pulled out the <V| and |V> and combined them to get <V|V>, but I don't get where the minus sign comes from, or how he gets any of the rest of the equation, so I'm assuming I'm wrong about where the <V|V> comes from.
I'm deeply sorry about the notation here, I typed this on a phone or I would've used LaTeX.
<Z|Z> >= 0
Mentioned in the first section.
So you know that
[tex] |Z\rangle = |V\rangle - \frac{\langle W|V\rangle}{|W|^2} |W\rangle[/tex]
So what do you think [itex]\langle Z|[/itex] equals?
kreil said:
So you know that
[itex]\langle Z|[/itex] should just equal [tex] \langle V| - \frac{\langle W|V\rangle}{|W|^2} \langle W|[/tex]
right? So if I look at [itex]\langle Z|Z \rangle[/itex], I have to distribute, but I can't see how he's getting the terms he's getting, namely because I don't think I'm too comfortable with Dirac notation yet.
1: [itex]\langle V | V \rangle = \langle V | V \rangle[/itex] obviously,
2: [itex]\langle V | - \frac{\langle W|V\rangle}{|W|^2} W \rangle[/itex] seems like it should equal [itex]- \frac{\langle W|V\rangle \langle V|W \rangle}{|W|^2}[/itex]
3: Probably the most confusing term for me:
[itex]\langle - \frac{\langle V|W \rangle}{|W|^2}W|V \rangle[/itex]
This seems to me like it should just be [itex]- \frac{\langle V|W \rangle \langle W|V \rangle}{|W|^2}[/itex] but this term doesn't appear anywhere in his final formulation really. I mean I guess [itex]\langle V|W \rangle[/itex] is equivalent to his [itex]\langle W|V \rangle ^*[/itex], but why does he get that conjugate instead of the [itex]\langle V|W \rangle[/itex] that I got?
4: then [itex]\langle - \frac{\langle W|V\rangle}{|W|^2} W|- \frac{\langle W|V\rangle}{|W|^2} W \rangle[/itex] is the first term where I think I'm getting confused. For some reason the term he gets from this has a complex conjugate in it, which I assume means he's moving [itex]| - \frac{\langle W | V \rangle}{|W|^2} \rangle[/itex] to the bra side, which I assume makes the top term a complex conjugate, leaving me with [itex]\langle - \frac{\langle W|V\rangle}{|W|^2}\frac{\langle W|V\rangle ^*}{|W|^2} W| W \rangle = \frac{ \langle W|V \rangle \langle W|V \rangle ^* \langle W|W \rangle}{|W|^4}[/itex]
At the end, my final answer would look like: [itex]\langle V | V \rangle - \frac{\langle W|V\rangle \langle V|W \rangle}{|W|^2} - \frac{\langle V|W \rangle \langle W|V \rangle}{|W|^2} + \frac{ \langle W|V \rangle \langle W|V \rangle ^* \langle W|W \rangle}{|W|^4}[/itex]
This seems like it may at least be equivalent to his formulation based on what I said in 3, but even this took kind of a mental leap for me in part 4 with moving a term over to the bra side. Is that a correct step? If so, why?
Thanks so much for any help. I'm losing sleep over this.
No problem, anyone that gets a science degree loses some sleep over a problem or two, so I know what boat you're in!
Does it help if I say that,
[itex] |Z\rangle = \langle Z|^{\dagger}[/itex]
[itex] \langle Z| = |Z\rangle ^{\dagger}[/itex]
and that,
[itex] \langle W |V \rangle ^{\dagger} = \langle W | V \rangle ^* = \langle V|W\rangle ...?[/itex]
(In other words, the inner product of a bra and a ket is a complex number, and the Hermitian conjugate of a complex number is simply its complex conjugate.)
This all means that,
[tex] \langle Z| = |Z\rangle^{\dagger} = \left( |V\rangle - \frac{\langle W|V\rangle}{|W|^2} |W\rangle \right) ^{\dagger} =\left( \langle V | - \frac{\langle W|V \rangle ^*}{|W|^2} \langle W| \right)[/tex]
So,
[tex] \langle Z | Z \rangle = \left( \langle V | - \frac{\langle W|V \rangle ^*}{|W|^2} \langle W| \right) \left( |V\rangle - \frac{\langle W|V\rangle}{|W|^2} |W\rangle \right)[/tex]
See also,
http://en.wikipedia.org/wiki/Bra–ket_notation#Inner_products_and_bras
Yes, that clears it up completely, thank you.
I can now actually see the part in the book where the asterisk denoting that the initial setup involved a complex conjugate has been worn away due to shoddy printing, so I feel a lot better about this whole thing in general now.
Thanks so much!
kreil said:
So you know that
Hmm.. I don't get why the proof starts with that |Z>
Mind to explain it, please? thanks :)
Towards the end they consider, <W|V><V|W> = |<V|W>|, which I cannot understand. Please explain someone.
