Direction of vibration of molecule with respect to transfer of heat
Heat causes molecules to vibrate, but the direction of this vibration can differ from the direction of heat transfer in conduction, convection, and radiation. In metallic conduction, the movement of electrons plays a more significant role in heat transfer than molecular vibrations. While individual molecules may vibrate in various directions, the overall net movement aligns with the direction of heat transfer. It's important to note that heat transfer occurs in three dimensions at the molecular level. Understanding these dynamics is crucial for comprehending heat transfer mechanisms.
shivakumar06
the heat causes the molecule to vibrate.how does the molecule vibrate in terms of angle formed by vibrating molecule and the direction of tranfer of heat in conduction, convention and radiation?
Science news on Phys.org
That would be really difficult to answer at individual molecule/atom level for conduction. If you are looking at conduction in metals, you should be worried more about movement of electrons which forms a major part of heat transfer and molecular vibration only a little. Having said that, the individual molecules may vibrate in directions other than the direction of heat transfer but the net movement will be in the direction of heat transfer (remember heat transfer is never in one direction - it is always 3 dimensional when you are looking at molecular level)
I was watching a Khan Academy video on entropy called: Reconciling thermodynamic and state definitions of entropy. So in the video it says: Let's say I have a container. And in that container, I have gas particles and they're bouncing around like gas particles tend to do, creating some pressure on the container of a certain volume. And let's say I have n particles. Now, each of these particles could be in x different states. Now, if each of them can be in x different states, how many total...
Thread 'Why work is PdV and not (P+dP)dV in an isothermal process?'
Let's say we have a cylinder of volume V1 with a frictionless movable piston and some gas trapped inside with pressure P1 and temperature T1. On top of the piston lay some small pebbles that add weight and essentially create the pressure P1. Also the system is inside a reservoir of water that keeps its temperature constant at T1. The system is in equilibrium at V1, P1, T1. Now let's say i put another very small pebble on top of the piston (0,00001kg) and after some seconds the system...
I need to calculate the amount of water condensed from a DX cooling coil per hour given the size of the expansion coil (the total condensing surface area), the incoming air temperature, the amount of air flow from the fan, the BTU capacity of the compressor and the incoming air humidity. There are lots of condenser calculators around but they all need the air flow and incoming and outgoing humidity and then give a total volume of condensed water but I need more than that. The size of the...
