Discover the Speed of Sound on a New Planet | Harmonics & Tube Type Explained
  • Thread starter Thread starter MissB16
    Harmonics
The crew on a new planet measured the speed of sound using a 50cm tube, finding resonant frequencies at 1620Hz and 1980Hz, resulting in a calculated speed of sound at 360 m/s. The discussion revolves around determining the harmonics associated with these frequencies and identifying the type of tube used, which is suggested to be open/closed. Participants express confusion over the formulas needed to calculate the harmonics and seek clarification on how to derive them. Key resources are shared to assist in understanding the relationship between frequency and harmonics for different tube types. The conversation emphasizes the importance of using the correct formulas to arrive at the harmonic numbers.
MissB16
I cannot figure this out! Please help!
Q: A Spaceship lands on a new planet. The crew decides to measure the speed of sound by blowing across one end of a tube. The tube is 50cm long, and the crew finds one resonant frequency at 1620Hz and the next resonant frequency at 1980Hz. What is the speed of sound? What is the number of each of the harmonics they found? What type of tube is the crew using- open/open, or open/closed?
I found the speed to be 360 m/s, but I have no idea how to find the harmonics! I don't know where to start! Help!
How did you find the speed?
What's the formula for the harmonics for each type of tube?
I found the speed by the equation v=lambda*f which both frequencies came out to 360
I'm not sure what the formulas are for the tubes...that's my problem. I don't know how to go about finding the harmonics. Hopefully you physics genius's can help me.
Honestly 360 is what it says on my answer key and I subtracted 1980 from 1620 so I found lambda by V/f=lambda... the answer key says it's the 9th and 11th harmonics with a open/closed tube...I just need an explanation of how they got that answer.
I'm not disputing the answer, only how you arrived at it. The way to get the answer is to use the formulas for the open and open/closed air columns that are in the links I gave you.
