Displacement and electric field
The discussion centers on the relationship between displacement (D) and electric field (E) expressed as D=εE, where the dielectric constant (ε) varies with volume (V) and temperature (T). Participants clarify that to express dD in terms of dV, dT, and dE, one must also consider the changes in ε, leading to the expression dε = (∂ε/∂V)dV + (∂ε/∂T)dT. The final formulation for dD incorporates these variations, resulting in dD = E[(∂ε/∂V)dV + (∂ε/∂T)dT] + εdE. The conversation concludes with confirmation that this approach is correct and aligns with the problem's requirements.
chemphys1
displacement and electric field related by D=εE where dielectric constant depends on volume and temperature. Express dD in terms of dV, dT and dE
(this is just a part of a question but want to make sure I have it right else the rest of the 'showing' and proofs are never going to work out)
so taking D=εE
Then dD = εdV (because it is volume dependent) + εdT (temperature dependent)
what happens to the E, is it Edε + edE as well as the above
although it can't be dε because it says express in terms of dT dV and dE, no dε mentioned?
is any of that on the right lines?
any help appreciated
We can write that predicate statement as ε = ε(V, T).
Based on that, you need to find an expression for dε in terms of dV and dT.
What would be the change in ε if T stays constant and V increases by dV?
chemphys1 said:
... dielectric constant depends on volume and temperature. although it can't be dε because it says express in terms of dT dV and dE, no dε mentioned?
/QUOTE]
The above is self-contradicory.
How can there be no dε when it says ε varies with T and V?
as in like this?
where does dD =
come into this?
rude man said:
/QUOTE]
true
I'm not very good at interpreting what maths questions mean/are saying :confused:
come up with this
dD = E∂ε + εdE
where
overall
dD = E [(∂ε/∂V)dV + (∂ε/∂T)dT] + εdE
is that what I should be getting?
chemphys1 said:
come up with this
dD = Edε + εdE
where
overall
Excellent!
