Displacement of String Waves at Point of Cross
  • Thread starter Thread starter aliciagu
    String Waves
The discussion revolves around the behavior of string waves, specifically the net displacement at a point where two pulses cross. The context involves understanding wave reflection in different boundary conditions: one where the string is rigidly fixed and another where it is free to move.
  • Participants explore the concept of wave reflection and its effects on displacement, questioning the behavior of the system under different boundary conditions. There are attempts to reason through the implications of linear superposition of wave displacements.
The discussion is active, with participants sharing their thoughts on the displacement outcomes for both scenarios. Some guidance has been offered regarding the nature of wave interactions, and there is a recognition of differing interpretations regarding the net displacement in the free-moving case.
Participants are considering the effects of boundary conditions on wave behavior, particularly focusing on the assumptions about wave inversion and the resultant displacements at the point of crossing. There is an ongoing examination of how these assumptions influence the overall understanding of the problem.
aliciagu
A series of pulses, each with an amplitude of .150 m are sent down a string that is attached to a post at one end. The pulses are reflected back and travel back along the string with no loss of amplitude. What is the net displacement of an element at a point on the string where the 2 pulses cross a. if the string is rigidly attached, b. if the end at which reflection occurs is free to slide up and down.
I know that in a rigidly fixed string, reflection inverts the waves, and if the string is free to move up and down, the reflected pulse is not inverted.
I am thinking that in a rigid system, the net displacement where the two pulses cross would be zero, because that point would be a node. If the system is free to move, then I think that the net displacement at the point where the waves meet would be plus or minus A. Is my brain working right?
Yes, the incoming and outgoing pulses are negatives of each other. Since waves add linearly, their sum is zero.
Hold up. Now the displacements of the incoming and outgoing waves have the same sign. How do numbers of the same sign add up?
So in the second one, the displacement would be 2A, because the sum of the 2 diplacements is (in this case) .300?
Now you've got it.
  • · Replies 17 ·
