Dissolving silver
  • Thread starter Thread starter ldanielrosa
The discussion focuses on refining silver from scrap using homemade nitric acid while minimizing waste. It highlights that a significant portion of the acid is lost during the oxidation of metals, with suggestions to use a dilute solution to reduce this loss. The optimal dilution is questioned to ensure that nitrogen dioxide (NO2) can redissolve and regenerate nitric acid. The conversation emphasizes the safety of using cold, weak acid to produce nitrogen monoxide (NO) and subsequently convert it to NO2 for further reactions. Overall, the goal is to enhance efficiency in the silver refining process while managing chemical reactions effectively.
ldanielrosa
TL;DR Summary
How dilute must it be to avoid destroying half the acid?
I'm making poor man's nitric acid to refine silver from scrap. I would like to waste as little as possible. I've noticed that about half the acid is destroyed oxidizing the metals, and I'd like to reduce that if possible. One reference mentioned that I lose only one in four in a "dilute solution" instead of half. How dilute must it be to allow the NO2 to disproportionate so that half of it will redissolve and become nitric acid again?
Chemistry news on Phys.org
Cold dilute acid will react to produce NO (reacts with oxygen to make NO2)
Hot concentrated will react to give NO2
NO2 will disolve in water SPARINGLY to produce a weak nitric acid ...
Probably safer to go with cold weak acid , catch the NO gas (clear) in a large container , add air to make it NO2 (brown) , add water and shake ... don't expect much yield.
Thread 'How to make Sodium Chlorate by Electrolysis of salt water?'
I have a power supply for electrolysis of salt water brine, variable 3v to 6v up to 30 amps. Cathode is stainless steel, anode is carbon rods. Carbon rod surface area 42" sq. the Stainless steel cathode should be 21" sq. Salt is pure 100% salt dissolved into distilled water. I have been making saturated salt wrong. Today I learn saturated salt is, dissolve pure salt into 150°f water cool to 100°f pour into the 2 gallon brine tank. I find conflicting information about brine tank...
Engineers slash iridium use in electrolyzer catalyst by 80%, boosting path to affordable green hydrogen https://news.rice.edu/news/2025/engineers-slash-iridium-use-electrolyzer-catalyst-80-boosting-path-affordable-green Ruthenium is also fairly expensive (a year ago it was about $490/ troy oz, but has nearly doubled in price over the past year, now about $910/ troy oz). I tracks prices of Pt, Pd, Ru, Ir and Ru. Of the 5 metals, rhodium (Rh) is the most expensive. A year ago, Rh and Ir...
