Distance between 2 atoms in a crystal
  • Thread starter Thread starter Nemo's
    Atoms Crystal
The discussion revolves around calculating the shortest distance between the centers of two adjacent atoms in a crystal composed of 27 atoms. The initial calculations led to a distance of 5.04*10^-10 meters, but the correct answer is identified as 3.4*10^-10 meters. Participants clarify that the density provided applies specifically to the small crystal, not larger volumes, which affects the interpretation of the volume and distance calculations. The confusion arises from the assumption about atom placement and the implications of edge atoms being closer together. Ultimately, the correct approach emphasizes understanding the crystal's structure and density in relation to the specific arrangement of atoms.
Nemo's
Given a crystal (cube) with regularly arranged atoms (Total 27 atoms)
The mass of each atom is 3.5*10^-25. The density of the crystal is 9.2*10^3
What is the shortest distance between the centres of two adjacent atoms?
density = mass / volume
Volume= (27*3.5*10^-25)/(9.2*10^3)=1.03*10^-27
Length(L)=1*10-9
Distance between two atoms is L/2=5.04*10^-10
Correct answer is 3.4*10^-9
do you thinkthis is the correct answer?
I think your "correct answer" is off by 10
L is correct. Should you really be dividing by 2?
Sorry the correct answer should be 3.4*10^-10
Should I divide by 3 then ? Why ?
What you probably did was to assume the volume of 27 atoms had an atom at every corner and one between. But if you put this volume next to another, the atoms on the edges would be to close. In fact, the distance should be 3.
So the atoms on the edges would be closer than others and that's the required "shortest distance"?
I just can't really imagine what it looks like
Maybe I wasn't clear. Put the atoms in a uniform rectangular three dimensional grid. My attachment shows the top view. Notice the volume is (3d)^3
The difficulty is, what does volume (and therefore density) mean when applied to a crystal consisting of only 27 atoms? It does not say that the density given is for arbitrarily large chunks of this material - it is for specifically this crystal of 27 atoms. So I tend to agree with Nemo's answer.
Good point, I guess whoever stated the "correct answer" thought it was for a large chunk.
