Calculating Distance Between Stop Signs Using Accelerated Motion Formulas
  • Thread starter Thread starter TonkaQD4
A car accelerates from rest at a stop sign, reaching a speed of 29.82 m/s after 7.10 seconds with an acceleration of 4.20 m/s². It then coasts for 2.10 seconds, covering an additional distance of 62.622 meters. The car subsequently decelerates at 3.10 m/s² until it stops at the next sign, requiring calculation of the time and distance for this phase. The total distance between the stop signs is calculated by summing the distances from all three intervals, leading to an estimated total of approximately 304.164 meters. Accurate application of kinematic equations is essential for determining the correct distances in each phase of motion.
TonkaQD4
A car starts from rest at a stop sign. It accelerates at 4.20m/s^2 for 7.10s, coasts for 2.10s, and then slows down at a rate of 3.10m/s^2 for the next stop sign. How far apart are the stop signs?
Please help me start this problem. Not sure where to begin. Thanks
1st Interval
Vf= 0 + 4.20m/s^2(7.10s)
= 29.82m/s
29.82m/s x 7.10s
= 211.72m
2nd Interval
29.82m/s x 2.10s
= 62.622m
3rd Interval
Vf = 29.82m/s - 3.10m/s^2(t)
-29.82m/s = -3.10m/s^2(t)
9.62s = t
29.82m/s - 3.10m/s^2(9.62s)
Well, do I have the first two intervals correct?
And I am stuck on the third interval... Does it just equal 29.82m, which means the distance between the two stop signs is 211.722+62.622+29.82= 304.164m
Any help would be greatly appreciated.
interval 1 is not right...
Remember this is accelerated motion... d = vt doesn't work here unless by v you mean "average velocity"...
what displacement formulas do you have for accelerated motion...
try to apply one here...
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
