Distance between two parallel lines
  • Thread starter Thread starter lubricarret
    Lines Parallel
The discussion revolves around determining the distance between two parallel planes represented by the equations –4x–4y+1z=–1 and 8x+8y–2z=12. Participants are exploring the geometric and algebraic methods to find this distance.
  • Exploratory, Mathematical reasoning, Problem interpretation
  • The original poster attempts to use vector projection to find the distance between the planes, while others suggest alternative methods, including finding the intersection of a line normal to one plane with the other plane.
Participants are actively engaging with the problem, with some providing corrections to the original poster's calculations. There is a mix of approaches being discussed, and while some guidance has been offered, no consensus has been reached on the best method to solve the problem.
Participants are working under the constraints of homework rules, which may limit the types of solutions or methods they can discuss. There is also an acknowledgment of potential mistakes in calculations that could affect the outcome.
lubricarret
Determine the distance between the parallel planes –4x–4y+1z=–1 and 8x+8y–2z=12
Proj_n_v = ((vn)/(nn))n
I thought I understood how to do this, but I am not getting a correct answer for it. What I did was:
I made the equations to be:
–4x–4y+1z=–1 and
–4x–4y+1z=–12
and therefore got the normal to these two planes to be: (-4,-4,1)
Then, I took a point P (0,0,-1) from plane 1. Then, took a point A on plane 2 to be (0,0,-12).
From these two points, I got vector AP = (0,0,11).
I projected vector AP onto the normal... so
proj_n_AP = (((AP)n)/(nn))n
And got the result: (11/33)[(-4,-4,1)]
I then got the distance by ll(11/33)[(-4,-4,1)]ll to be (11/33)sqrt33
Am I doing this totally wrong? Thanks!
No, you are doing it right. You just made a booboo. Dividing 8x+8y–2z=12 by -2 gives –4x–4y+1z=–6, doesn't it?
Aa! Can't believe I made such a stupid mistake. Thanks!
So, the answer would just be (5/33)(sqrt33), correct?...
As I would keep P as (0,0,-1), but make A (0,0,-6); and get the vector AP = (0,0,5)
So, projecting AP onto the normal, and then getting the distance of the projection would result in: (5/33)(sqrt33)
That seems right.
But why bother with projecting? You know that a point on plane 1 is (0, 0, -1) and that the normal vector is given by <-4, -4 , 1> so a line through that point, normal to the plane is x= -4t, y= -4t, z= -1+ t. Where does that line intersect plane 2? The distance between those two points is the distance between the planes.
