Divisible of natural numbers
In summary: Sure, let me explain. In the first case, we are looking at numbers divisible by 2 but not by 3 or 4. So we start with the total number of choices, which is 60 (since we have 120 numbers and we are only considering the first half, i.e. the even numbers). Then, we divide by 2 to find the numbers that are divisible by 2. However, this includes numbers that are also divisible by 3 or 4, so we need to subtract those numbers. That's why we subtract 60/3 and 60/4. But, this also counts numbers that are divisible by both 3 and 4, so we need to add back in the
Alexsandro
51
Could Someone help with this question of probability ?
What is the probability that a number of the set [itex]\Omega[/itex], first 120 natural numbers {1,2,3, ... , 120}, picked at random is not divisible by any of the number 3, 4, 6 but is divisible by 2 or 5 ?
Well, the first problem is to figure out just what you mean by "picking a natural number at random".
(P.S. there is no such thing as a uniform distribution on the naturals)
Answer: (1/4 - 1/12) + (1/5 - 1/15 - 1/20)
Explanation:
Half of the numbers will be divisible by two. Out of these, another half will be divisible by four and shall be excluded, hence we end up with 1/4. These numbers will be of the form 4n+2, and none of them will be divisible by 3. However, 1 out of 3 of these will be divisible by 6, so we subtract 1/3 * 1/4 = 1/12 from 1/4 to get those numbers divisible by 2 but not by 3,4, or 6.
One fifth of the numbers are divisible by five. Out of these, multiples of 15 will be divisible by 3, multiples of 20 will be divisible by 4, and multiples of 30 will be divisible by 6. However, half of the multiples of 15 are also multiples of 30, so we don't need to include a 1/30 term, as it is already covered by the 1/15 term. So the probability of a number being divisible by 5 but not by 3,4, or 6 is 1/5 - 1/15 - 1/20.
Adding the two probabilities together gives the final answer for a random natural number being divisible by either 2 or 5 but not by 3,4, or 6.
Sorry, I forgot to say that this question refers to set [itex]\Omega[/itex] of the first 120 natural numbers {1,2,3, ... , 120}. I'd like to know what probability that a natural number this set [itex]\Omega[/itex] is not divisible by 3, 4 and 6 but is divisible by 2 or 5.
I thank if someone help me!
Brute force doesn't hurt. If it is divisbile by 2 and 5, then it is divisible by 10. There are only 12 multiples of 10 in the first 120 numbers. Just count those which are not divisible by 3,4, or 6.
The divisible if for 2 OR 5, not 2 AND 5 !
Ok, I stand corrected. My apologies on the error in reading.
Nevertheless, the brute force approach still works. Use the sieve of Eratothenes (write all numbers from 1 to 120 and cross them off as they violate your requirements).
Then divide the number of numbers that remain by 120.
This is too low- you've removed the numbers divisible by 5 and not divisible by 3 AND 4 twice. Similar problem for your end result, you need to also remove the numbers divisible by 2 AND 5, but not 3 and 4 as these were counted twice.
Alexsandro, what are you able to do on this problem? Post some work and it will be easier to offer some help. Can you answer some simpler questions like:
What is the probability a number is divisible by 2 and not divisible by 3?
What is the probability a number is divisible by 2 and not divisible by 3 and 4?
______________________
Ok Shmoe,
I am going to show as I answered to this question.
Consider the events and [itex]\Omega[/itex] = {1,2,3, ..., 120}, natural numbers:
A = {integers which are divisible by 3}, with P(A) = 1/3;
B = {integers which are divisible by 4}, with P(B) = 1/4;
C = {integers which are divisible by 6}, with P(C) = 1/6;
D = {integers which are divisible by 2}, with P(D) = 1/2;
E = {integers which are divisible by 5}, with P(E) = 1/5.
I need to find the probability of the set: [itex]A^cB^cC^c(D \cup E)[/itex].
Let [itex]A^cB^cC^c(D \cup E)[/itex] = [itex](A^cB^cC^cD) \cup (A^cB^cC^cE)[/itex].
and
[itex](A^cB^cC^cD) \cap (A^cB^cC^cE) = (A^cB^cC^cDE) = DE - ABCDE.[/itex]
then
[itex]P(A^cB^cC^cDE)[/itex] = P(DE) - P(ABCDE) = 1/10 - 1/60 = 1/12.
P(DE) = 1/10;
P(ABCDE) = 1/60.
and
[itex]P(A^cB^cC^cD)[/itex] = P(D) - P(ABCD) = 1/2 - 1/12 = 5/12.
[itex]P(A^cB^cC^cE)[/itex] = P(E) - P(ABCE) = 1/5 - 1/60 = 11/60.
[itex](A^cB^cC^cD) \cup (A^cB^cC^cE)[/itex] = [itex]P(A^cB^cC^cD)[/itex] + [itex]P(A^cB^cC^cE)[/itex] - [itex]P(A^cB^cC^cDE)[/itex] = 5/12 + 11/60 - 1/12 = 31/60
However, the right answer is 14/60. I committed some error? Where I can have wrong?
If it is divisible by 2 you have 60 choices
1 , 2 , 3 ... ,59 , 60 all multiply by 2
we remove 60/2 +60/3 -60/6=40
it remains 60-40 =20
if it divides 5 we have 1,2,3 ,...,24 all multiply by 5
we remove 24/3 +24/4-24/12=12
what remains 24-12=12
We have four common cases above
2*5=5*2
2*25=5*10
2*35=5*14
2*55=5*22
then
20+12-4=28
p=28/120=7/30
doubt
2*5=5*2
2*25=5*10
2*35=5*14
2*55=5*22
then
20+12-4=28
p=28/120=7/30
_______________
I didn't understand the removings that you did. Please, could you explain it.
"we remove 60/2 +60/3 -60/6=40
it remains 60-40 =20 "
and
"we remove 24/3 +24/4-24/12=12
2*5=5*2
2*25=5*10
2*35=5*14
2*55=5*22
then
20+12-4=28
p=28/120=7/30"
thanks
If we have
(1,2 ,3 ,... ,59,60 all multiplied by 2
and we want to find the number the divides 2 or 3)
that is equivalent to finding the number that divides 4 or 6 in
the numbers 2,4,6,8 ...,118,120
So if we have
1,2,3,... ,59,60
and we want to remove the numbers that divides 2 or 3
First we remove the numbers that divides 2
which is 2,4 ,6 ,... ,58,60
Which is equal to 60/2=30
Now the numbers that divides 3
3,6,9 ,..., 57,60
which is equal to 60/3=20
Now we removed twice the number that divides both 2 and 3 which is
multiple of 6
6,12,18,... ,60
or equal to 60/6=10
Now we removed 30+20 -10=40
it remains 60-40=20
The same thing for 5
Now we try to figure the numbers that are common on both counting of 2
and 5
we have among the set (1,2,...59,60) that divides 5 are
5,10,15,20,25,30,35,40,45,50,55,60
We exclude the numbers the divides 2 or 3 . We have then the four cases as
follow
5,25,35,55
finally the number that satisfies the conditions of the problem=20+12-4=28
p=28/120
1. What are natural numbers?
Natural numbers are the set of positive integers starting from 1 and counting infinitely, such as 1, 2, 3, 4, etc. They are also known as counting numbers.
2. What does it mean for a number to be divisible?
A number is divisible by another number if it can be divided evenly without leaving a remainder. For example, 12 is divisible by 3 because 12 ÷ 3 = 4 with no remainder.
3. How do you determine if a number is divisible by another number?
To determine if a number is divisible by another number, you can use the division algorithm. This involves dividing the larger number by the smaller number and checking if the result is a whole number. If it is, then the number is divisible.
4. What is the difference between prime and composite numbers?
A prime number is a natural number that is only divisible by 1 and itself. Examples include 2, 3, 5, 7, etc. A composite number is a natural number that has more than two factors, meaning it is divisible by numbers other than 1 and itself. Examples include 4, 6, 8, 9, etc.
5. How can we use divisibility rules for quick mental calculations?
Divisibility rules are shortcuts that can help determine if a number is divisible by another number without actually performing the division. For example, a number is divisible by 3 if the sum of its digits is divisible by 3. These rules can be helpful for quick mental calculations and are often taught in elementary school.
  • Math POTW for Secondary and High School Students
  • Precalculus Mathematics Homework Help
  • Set Theory, Logic, Probability, Statistics
