Appliances How Much Motor Power is Needed for a DIY Drum Coffee Roaster?
  • Thread starter Thread starter Hemipatuca
    Coffee Drum
To determine the appropriate motor power for a DIY drum coffee roaster with a drum and load of 50 pounds, rotating at 10-60 RPM and measuring 20 to 30 cm in length, key factors include the desired speed, friction encountered during operation, and torque requirements. Friction primarily arises from the tumbling of coffee beans, making it essential to reference the specifications of similar commercial roasters to gauge motor size and power. A comparable device drew 16 Amps at 110 volts, indicating a potential power range. Conducting experiments by building the roaster and measuring the power needed to achieve the desired speed can provide a more accurate basis for selecting the optimal motor. Additionally, considering components from small electric clothes dryers may offer useful insights and parts for the project.
Hemipatuca
Hello, My name is Héctor and I love coffee, I'm working on a diy drum coffee roaster. Drum + load= 50 pounds, rotation needed = 10-60 Rpm, length from 20 to 30 cm. How can I determine the motor power that can turn my drum? Can someone help me please?
Thank you in advance
Any power has the potential to turn that drum.
What you need to know is how fast you want to spin it up and what type of friction it will encounter.
A main source of friction is the tumbling of the beans.
I would track down the service manual to a commercial roaster similar in size to the one you are using to find out what they are using.
A quick survey didn't show me anything specific. But one device similar in size to yours (perhaps a somewhat smaller) drew 16 Amps at 110 volts.
You're going to need to be concerned about speed control as well.
Likes anorlunda
Thank you for your reply, I'm aware that there are a lot of motors that can work but I don't want to underutilize power nor money. I would like to know how many hps or torque is needed to choose the correct one.
Thank you again
I think you missed @.Scott 's point. The size of the motor depends mostly on friction. You (and we) have no way to estimate how much friction.
Therefore, your best approach is to see what size motors other coffee roasters use. The manufacturers of those other roasters may have done experiments to measure the friction.
You other possibility is to do your own experiments. Build the coffee roaster and try spinning it at the desired speed. Measure how much power that takes, and use that number to select the optimum motor.
Likes NTL2009
Hemipatuca said:
Summary: DIY coffee roaster
Reference https://www.physicsforums.com/threads/force-needed-to-rotate-a-drum.915197/
I note in passing that these requirements are not dissimilar to a small electric clothes dryer. Might be a source for parts/ ideas.
