Electrical Can I Use JB Weld to Build DIY High Voltage Vacuum Feedthroughs?
Using JB Weld for DIY high voltage vacuum feedthroughs raises concerns about its electrical properties and dielectric strength. While some users report JB Weld performs well in vacuum conditions, it is crucial to verify its ability to withstand the intended voltage without breakdown. The discussion emphasizes the importance of having the correct alumina thickness based on the voltage applied and suggests that testing the epoxy with higher voltages is advisable. Additionally, it is recommended to consider purchasing commercially available feedthroughs if they meet the required specifications at a reasonable cost. Overall, careful evaluation of materials and design is essential for ensuring safety and effectiveness in high voltage applications.
SupaVillain
I want to build high voltage feedthroughs (vacuum) from epoxying pieces of alumina together, and then epoxying alumina strips on the outside to cover the spaces between. Can I use JB weld, as far as things go electrically? People have reported that JB weld is unexpectedly wonderful for vacuum.
Provided I have the correct amount of alumina per the amount of kv I am applying to it, the electricity won't break down or break through the linings of epoxy will it? It's very expensive to get blocks of alumina and machine them
I think it would be useful to see a drawing of the feedthrough and where you intend to use the epoxy. Also what vacuum are you trying to maintain?
A vacuum of 10-4 torr, it's really not a question of design it's more about the epoxy, I am asking if the voltage will be able to move through the epoxy and connect to the vacuum chamber or other nearby objects within the voltages reach.
http://www.jb-weld.co.uk/technical-data-sheets
Unless you have the specs on it dielectric strength, or test it with at least twice voltage you intend to use I wouldn't use it. Why do you have to make your own feed through? Experimental rule: if you can buy a part that meets your needs at a reasonable price then buy it. High voltage vacuum feed throughs are common accessories for vacuum systems.
The idea is to use water to shift the centre of gravity of the pendulum by a small amount. The pendulum rod will have a tube closed at the bottom and open at the top. A second similar tube will be mounted nearby and will act as a reservoir. The water will be transferred using a peristaltic pump driven by a stepper motor and will travel via a thin flexible silicon tube. A loop arrangement will minimise friction at the pendulum's fulcrum. The silicon tube will extend to the bottom of the...
Philips Hue was the very first provider of smart LED bulbs that can be controlled wirelessly. Over the years, as Philips sold ever improved models of smartbulbs, it became very difficult to identify exactly which model one of their bulbs is. Once I've installed a smart bulb, there is some additional information in the Hue app about the bulb model, but even then, I found that it requires information from both the app and from what's printed on the outside of bulb to be sure what the actual...
Some time ago I posted this Raspberry PI DIY Mass Spec using Raman Scattering. It's was something of a cumbersome project though, needing a 3D printer and special heat-resistant plastic giving of carcinogenic fumes during printing. To be blunt it was also not very mobile and interpreting the results was further cumbersome Recently though, I've been told that Arduino, and it's various sensor packages, has matured to the point where it's a usable alternative. Now I realize that a cigarette...
Hot Threads
